Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Data Management toolbox > Table toolset > Tools
Analyze (Data Management) (ArcInfo and ArcEditor only)
Release 9.3
Last modified March 8, 2012
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Tools"
Related Topics
NOTE: This topic was updated for 9.3.1.
Updates relational database management system (RDBMS) statistics of business tables, feature tables, and delta tables along with the statistics of those tables' indexes
Usage tips
Command line syntax
An overview of the Command Line window
Analyze_management <in_dataset> <BUSINESS | FEATURE | RASTER | ADDS | DELETES>
Parameter Explanation Data Type
<in_dataset>
The table or feature class to be analyzed.
Layer | Table View | Dataset
The component type to be analyzed.
  • BUSINESS — Updates business rules statistics
  • FEATURE — Updates feature statistics
  • RASTER — Updates statistics on raster tables
  • ADDS — Updates statistics on added datasets
  • DELETES — Updates statistics on deleted datasets
The Add Value button, which is used only in ModelBuilder, allows you to add expected values so you can complete the dialog box and continue to build your model.
String
Data types for geoprocessing tool parameters
Command line example
workspace "Database Connections\Oracle_SDE.sde"
Analyze oraspatial.accident BUSINESS
Scripting syntax
About getting started with writing geoprocessing scripts
Analyze_management (in_dataset, components)
in_dataset (Required)
components (Required)
String
Script example
# Purpose: Analyze a database table after data loading
# Create the Geoprocessor object
import arcgisscripting
gp = arcgisscripting.create()
try:
    # Set the workspace (to avoid having to type in the full path to the data every time)
    gp.Workspace =  "Database Connections/Oracle_SDE.sde"
    # Process: Update business rules statistics of a table
    gp.Analyze("oraspatial.accident", "BUSINESS")
except
    # If an error occurred while running a tool, print the messages
    print gp.GetMessages()
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
