Show Navigation | Hide Navigation
You are here:
Geoprocessing > Automating your work with scripts > Accessing tools within a geoprocessing script
Error handling with Python
Release 9.3
Last modified June 3, 2010
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Accessing tools within a geoprocessing script"
Related Topics
Note: This topic was updated for 9.3.1.
Errors happen. Writing scripts that expect and handle errors can save you a lot of time and frustration. When a tool writes an error message, the geoprocessing object generates a system error, or exception. In Python, you can provide a variety of structures and methods that can handle exceptions. Of course, a script can fail more many other reasons that are not specifically related to a geoprocessing tool; these too need to be caught and dealt with in an appropriate manner. The following sections offer a few techniques that introduce the basics of Python exception handling.
Geoprocessing tool errors are accompanied by a six-digit code. These ID codes have been documented to provide additional information on their cause and how they can be dealt with.
Learn more about creating and debugging geoprocessing scripts
Learn more about script tools
Try/Except statement
A try/except statement can be used to wrap entire programs or just particular portions of code to trap and identify errors. If an error occurs within the try statement, an exception is raised, and the code under the except statement is then executed. Using a simple except statement is the most basic form of error handling.
In the following code, Buffer fails because the required Distance parameter has not been used. Instead of failing without explanation, the except statement is used to trap the error, then fetch and print the error message generated by Buffer. Note that the except block is only executed if Buffer returns an error.
try:
    gp.buffer_analysis("c:/transport/roads.shp", "c:/transport/roads_buffer.shp")
except:
    print "Error"
    print gp.getmessage(2)
Raise statement
The previous example dealt with handling an exception that occurred in the code; in some cases, it may be necessary to create exceptions yourself. A raise statement can be used for this purpose. In the following code, a raise statement is used when an input feature class has been identified as having no features. This is not strictly an error but is a condition that the code can be used to guard against.
import arcgisscripting
import os
gp = arcgisscripting.create(9.3)
gp.overwriteoutput = 1
fc = gp.GetParameterAsText(0)
try:
    # Check that the input has features
    if gp.getcount(fc) > 0:
        gp.featuretopolygon(fc, os.path.dirname(fc) + os.sep + "out_poly.shp")
    else:
        raise "no features"
except "no features":
    # The input has no features
    print fc + " has 0 features."
except:
    # By default any other errors will be caught here
Traceback
In larger, more complex scripts, it can be difficult to determine the precise location of an error. Python's sys and traceback modules can be used together to isolate the exact location and cause of the error, identifying the cause of an error more accurately and saving you valuable debugging time.
In addition, not all errors are the same, and in many cases you will want to handle different types of errors in different ways. For instance, in the following example, the code handles geoprocessing tool errors differently from all other types of errors.
# Import the required modules
import sys
import traceback
gp = arcgisscripting.create()
try:
    # Your code goes here
    # See the table below for examples
except arcgisscripting.ExecuteError:
    # Get the geoprocessing error messages
    msgs = gp.GetMessage(0)
    msgs += gp.GetMessages(2)
    # Return gp error messages for use with a script tool
    gp.AddError(msgs)
    # Print gp error messages for use in Python/PythonWin
    print msgs
except:
    # Get the traceback object
    tb = sys.exc_info()[2]
    tbinfo = traceback.format_tb(tb)[0]
    # Concatenate information together concerning the error into a
    #   message string
    pymsg = tbinfo + "\n" + str(sys.exc_type)+ ": " + str(sys.exc_value)
    # Return python error messages for use with a script tool
    gp.AddError(pymsg)
    # Print Python error messages for use in Python/PythonWin
    print pymsg
If the above code was used and a geoprocessing tool error occurred, such an invalid input, this would raise arcgisscripting.ExecuteError, and the first except statement would be used. This statement would print out the error messages using the GetMessages method. If the same code was used but a different type of error occurred, the second except statement would be used. Instead of printing geoprocessing messages, it would get a traceback object and print out the appropriate system error messages.
The table below shows the expected errors that result from three different lines of codes that could be substituted into the code above. The first is a geoprocessing tool error and uses the first except statement. The second and third examples are not specifically caught and use the general except statement.
Your code Resulting error
gp.getcount("")
    Executing: GetCount # 0
    Failed to execute. Parameters are not valid.
    ERROR 000735: Input Rows: Value is required
    Failed to execute (GetCount).
x = "a" + 1
    File "c:\temp\errortest.py", line 10, in <module>
    x = "a" + 1
    <type 'exceptions.TypeError'>: cannot concatenate 'str' and 'int' objects
float("a text string")
    <type 'exceptions.ValueError'>: invalid literal for float(): a text string
The example above assumes you are creating the geoprocessor using the arcgisscripting module. If using win32com.client to create the geoprocessor, your code would remain largely the same, but would require some minor changes (shown in bold).
import win32com.client
import pywintypes
import sys
import traceback
gp = win32com.client.Dispatch("esriGeoprocessing.GpDispatch.1")
try:
except pywintypes.com_error:
    gp.AddError(msgs)
    print msgs
except:
    #   message string
    gp.AddError(pymsg)
    print pymsg
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
