Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Analysis toolbox > Extract toolset > Tools
Clip (Analysis)
Release 9.1
Last modified August 15, 2005
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Tools"
Related Topics
Extracts input features that overlay the clip features.
Learn more about how Clip (Analysis) works
Illustration
Clip illustration
Usage tips
Command line syntax
Introducing geoprocessing methods—Using dialog boxes and the command line
Clip_analysis <in_features> <clip_features> <out_feature_class> {cluster_tolerance}
Parameter Explanation
<in_features>
The features to be clipped.
<clip_features>
The features used to clip the input features.
<out_feature_class>
The feature class to be created.
{cluster_tolerance}
Cluster tolerance is the distance range in which all vertices and boundaries in a feature class are considered identical or coincident. To minimize error, the cluster tolerance chosen should be as small as possible, depending on the precision level of your data. By default, the minimum possible tolerance value is calculated in the units of the spatial reference of the input.
Command line example
workspace E:\arcgis\ArcTutor\Geoprocessing\San_Diego
Clip_analysis majorrds.shp study_quads.shp study_roads.shp
Scripting syntax
Introducing geoprocessing methods—Running a script
Clip_analysis (in_features, clip_features, out_feature_class, cluster_tolerance)
in_features (Required)
clip_features (Required)
out_feature_class (Required)
cluster_tolerance (Optional)
Script example
#Purpose: Determine the type of vegetation within 100 meters of all stream crossings
#Create the Geoprocessor object
from win32com.client import Dispatch
gp = Dispatch("esriGeoprocessing.GPDispatch.1")
try:
#Set the workspace (to avoid having to type in the full path to the data every time)
    gp.Workspace = "c:/projects/RedRiverBasin/data.mdb"
 # Process: Find all stream crossings (points)
    gp.Intersect("roads ; streams ", "stream_crossings", "#", 1.5, "point")
# Process: Buffer all stream crossings by 100 meters
    gp.Buffer("stream_crossings","stream_crossings_100m", "100 meters")
 # Process: Clip the vegetation feature class to stream_crossing_100m
    gp.Clip("vegetation", "stream_crossings_100m", "veg_within_100m_of_crossings")
# Process: Summarize how much (area) of each type of vegetation is found within 100 meters of the stream crossings
    gp.Statistics("veg_within_100m_of_crossings", "veg_within_100m_of_crossings_stats","shape_area sum","veg_type")
except:
#If an error occurred while running a tool print the messages
    print gp.GetMessages()
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
