ArcMap Standard toolbar |
Release 9.2
Last modified August 6, 2007 |
The Standard toolbar most typically appears at the top of the ArcMap application window and is used for map printing, creating a new map, opening an existing map, saving your map, starting related ArcGIS applications, and more.
| Button | Name | Function |
New map file | Creates a new map |
Open | Opens an existing map |
Save | Saves the current map |
Prints the current map | |
Cut | Cuts the selected element(s) |
Copy | Copies the selected element(s) |
Paste | Pastes the clipboard contents into your map |
Delete | Deletes the selected element(s) |
Undo | Undoes the last action |
Redo | Redoes the previously undone action |
Add Data | Adds new data to the map's active data frame |
Editor toolbar | Shows the Editor toolbar so you can edit the map's data |
Launch ArcCatalog | Starts ArcCatalog |
Show/Hide ArcToolbox | Shows/Hides the ArcToolbox window |
Show/Hide Command Line window | Shows/Hides the Command Line window |
What's This? | Allows you to get help for a menu command or tool by clicking the What's This pointer and clicking the menu command or tool |
