Goodes Homolosine |
Release 9.2
Last modified August 3, 2007 |
The Goode's Homolosine map projection is designed to minimize distortion for the entire world. It is an interrupted pseudocylindrical equal area projection. John Paul Goode developed the projection in 1925.
Goode's homolosine projection is a combination of the Mollweide and sinusoidal projections. The Mollweide projection is used for north of 40° 44' and south of -40° 44' approximately. The sinusoidal projection is used between those two latitude values for the equatorial part of the world. Both projections are equal area and pseudocylindrical. The projections are interrupted so that either the land masses except for Antarctica or the oceans are connected.
All latitudes are straight lines. There are six straight longitude lines due to the interrupted nature of the projection. Each lobe has its own central meridian, although the overall central meridian is zero. You can change the overall central meridian but that will cause the land masses or oceans do no longer be contiguous. For the land-oriented version, the straight longitude values are -100 and 30 in the northern hemisphere and -160, -60, 20, and 140 in the southern hemisphere. The ocean-oriented version uses -140, -10, and 130 in the northern hemisphere and -100, 20, and 140 in the southern hemisphere.
Useful only as a world map.
Used for an equal area world map, mainly for raster data. The USGS EROS data center provides data in Goode's Homolosine.
