Polar Stereographic |
Release 9.2
Last modified August 3, 2007 |
Print all topics in : "Supported map projections" |
The projection is equivalent to the polar aspect of the Stereographic projection on a spheroid. The central point is either the North Pole or the South Pole. This is the only polar aspect planar projection that is conformal. The Polar Stereographic projection is used for all regions not included in the UTM coordinate system, regions north of 84° N and south of 80° S. Use UPS for these regions.
Learn more about the Stereographic projection
Planar perspective projection, where one pole is viewed from the other pole. Lines of latitude are concentric circles. The distance between circles increases with distance from the central pole.
A single point, either the North Pole or the South Pole. If the plane is secant instead of tangent, the point of global contact is a line of latitude.
All meridians.
Normally not extended more than 90° from the central pole because of increased scale and area distortion.
Polar regions (conformal).
In the UPS system, the scale factor at the pole is 0.994, which corresponds to a latitude of true scale (standard parallel) at 81°06'52.3" N or S.
