The OGC well-known text representation of spatial reference systems |
Release 9.2
Last modified April 3, 2008 |
Print all topics in : "Feature geometry and raster data storage" |
The well-known text representation of spatial reference systems provides a standard textual representation for spatial reference system information.
The definitions of the well-known text representation are modeled after the POSC/EPSG coordinate system data model.
A spatial reference system, also referred to as a coordinate system, is a geographic (latitude-longitude), a projected (x,y), or a geocentric (x,y,z) coordinate system.
The coordinate system is composed of several objects. Each object has a keyword in uppercase (for example, DATUM or UNIT) followed by the defining, comma-delimited parameters of the object in brackets.
Some objects are nested; the objects themselves are composed of objects. Implementations are free to substitute standard brackets ( ) for square brackets [ ] and should be prepared to read both forms of brackets.
The Extended Backus Naur Form (EBNF) definition for the string representation of a coordinate system is as follows, using square brackets (see note above):
<coordinate system> = <projected cs> | <geographic cs> | <geocentric cs>
<projected cs> = PROJCS["<name>", <geographic cs>, <projection>, {<parameter>,}* <linear unit>]
<projection> = PROJECTION["<name>"]
<parameter> = PARAMETER["<name>", <value>]
<value> = <number>
PROJCS["NAD_1983_UTM_Zone_10N",
<geographic cs>,
PROJECTION["Transverse_Mercator"],
PARAMETER["False_Easting",500000.0],
PARAMETER["False_Northing",0.0],
PARAMETER["Central_Meridian",-123.0],
PARAMETER["Scale_Factor",0.9996],
PARAMETER["Latitude_of_Origin",0.0],
UNIT["Meter",1.0]]
<geographic cs> = GEOGCS["<name>", <datum>, <prime meridian>, <angular unit>] <datum> = DATUM["<name>", <spheroid>] <spheroid> = SPHEROID["<name>", <semi-major axis>, <inverse flattening>] <semi-major axis> = <number> <inverse flattening> = <number> <prime meridian> = PRIMEM["<name>", <longitude>] <longitude> = <number>
GEOGCS["GCS_North_American_1983", DATUM["D_North_American_1983", SPHEROID["GRS_1980",6378137,298.257222101]], PRIMEM["Greenwich",0], UNIT["Degree",0.0174532925199433]]
<angular unit> = <unit> <linear unit> = <unit> <unit> = UNIT["<name>", <conversion factor>] <conversion factor> = <number>
PROJCS["NAD_1983_UTM_Zone_10N", GEOGCS["GCS_North_American_1983", DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137,298.257222101]], PRIMEM["Greenwich",0],UNIT["Degree",0.0174532925199433]], PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",500000.0], PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-123.0], PARAMETER["Scale_Factor",0.9996],PARAMETER["Latitude_of_Origin",0.0], UNIT["Meter",1.0]]
<geocentric cs> = GEOCCS["<name>", <datum>, <prime meridian>, <linear unit>]
