Corridor |
Release 9.2
Last modified January 3, 2008 |
Print all topics in : "Distance (Spatial Analyst)" |
Calculates the sum of accumulative costs for two input accumulative cost rasters.
Learn more about how Corridor works
Usage tips
Command line and Scripting
Any two floating-point rasters can be used for the input (for example, an accumulative cost raster), but both inputs should be the result of a global cost function.
If the two input rasters were created from a global cost function and left unaltered, the output will always contain floating-point values.
The order of input is irrelevant.
Map Algebra
Learn more about how to specify the input raster dataset in the Map Algebra expression of Raster Calculator.
ArcObjects
The output from the ArcObjects method is a raster object.
Command line syntax
An overview of the Command Line window
Corridor_sa <in_distance_raster1> <in_distance_raster2> <out_raster>
| Parameter | Explanation | Data Type |
| <in_distance_raster1> |
An input raster that was the output accumulated cost raster from a global cost function. |
Composite Geodataset |
| <in_distance_raster2> |
| <out_raster> |
The raster to be created. |
Raster Dataset |
Corridor_sa C:/data/raster_1 C:/data/raster_2 C:/data/final_1
Scripting syntax
About getting started with writing geoprocessing scripts
Corridor_sa (in_distance_raster1, in_distance_raster2, out_raster)
| in_distance_raster1 (Required) |
| in_distance_raster2 (Required) |
| out_raster (Required) |
Raster Dataset |
# Corridor_sample.py
# Description:
# Calculates the sum of accumulative costs for two input
# accumulative cost rasters.
# Requirements: None
# Author: ESRI
# Date: Sept 6, 2005
# Import system modules
import arcgisscripting
# Create the Geoprocessor object
gp = arcgisscripting.create()
try:
# Set local variables
InRaster1 = "C:/data/raster_1"
InRaster2 = "C:/data/raster_2"
OutRaster = "C:/data/final_1"
# Check out Spatial Analyst extension license
gp.CheckOutExtension("Spatial")
# Process: Corridor
gp.Corridor_sa(InRaster1, InRaster2, OutRaster)
except:
# If an error occurred while running a tool, then print the messages.
print gp.GetMessages()
Map Algebra syntax
Corridor(<accum_grid1>, <accum_grid2>)
| <accum_grid1> | An input raster that was the output accumulated cost raster from a global cost function. |
| <accum_grid2> | An input raster that was the output accumulated cost raster from a global cost function. |
corridor(ingrid1, ingrid2) corridor(ingrid1, (ingrid2 + ingrid3)) corridor(ingrid1, costdistance(source, weight))
ArcObjects syntax
IDistanceOp::Corridor (distance1 As IGeoDataset, distance2 As IGeoDataset) As IGeoDataset
| distance1 | An input Raster that was the output accumulated cost raster from the IDistance::CostDistance or other Cost method. |
| distance2 | An input Raster that was the output accumulated cost raster from the IDistance::CostDistance or other Cost method. |
' Create the RasterDistanceOp object
Dim pDistanceOp As IDistanceOp
Set pDistanceOp = New RasterDistanceOp
' Declare the input distance 1 raster object
Dim pDistance1Dataset As IGeoDataset
' Calls function to open a raster dataset from disk
Set pDistance1Dataset = OpenRasterDataset("D:\SpatialData", "dist1raster")
' Declare the input distance 2 raster object
Dim pDistance2Dataset As IGeoDataset
Set pDistance2Dataset = OpenRasterDataset("D:\SpatialData", "dist2raster")
' Declare the output raster object
Dim pOutputRaster As IGeoDataset
' Calls the method
Set pOutputRaster = pDistanceOp.Corridor(pDistance1Dataset, pDistance2Dataset)
