An overview of general settings |
Release 9.2
Last modified October 30, 2007 |
Print all topics in : "Environment categories" |
General settings apply to most tools and contain things such as the current and scratch workspace and the output coordinate system.
The following subtopics supplement the reference topics found in Environment settings.
There are two workspaces that can be set on the Environment Settings dialog box—Current Workspace and the Scratch Workspace.
You can specify the coordinate system that will be applied to spatial data created by running tools. The coordinate system (geographic or projected) defines the location of the spatial data on the earth.
Precedence rules dictate which coordinate system is applied to outputs from running tools.
This environment setting determines how fields will be named when performing relational joins between tables. The default (QUALIFIED) is to name a field with the format tableName.fieldName. You can set this parameter to UNQUALIFIED so that fields will be named with the format fieldName.
In the majority of cases, you should use the QUALIFIED form, since it ensures that fields will be uniquely named on the joined table. The UNQUALFIED option should only be used when your output join table is a shapefile. When shapefiles are created, field names longer than 8 characters are truncated, so using the QUALIFIED format would probably result in duplicate field names.
Help for geographic transformations can be found in the following links:
If your input feature classes contain z-values in the feature geometry or you have set Output has z-values to ENABLED in the General Settings section of the Environment Settings dialog box, you can set a default output z-value. This default z-value will be given to each vertex in the output feature class after a tool is run, only if no z-value can be obtained from the input.
Each vertex in the feature class will contain an x, y, and z coordinate. The value for the z coordinate will be based on the input to the tool. If the input does not contain z-values, the value set for the default output z-value setting in the Environment Settings dialog box will be applied as the z-value to all vertices in the output feature class. If no default output z-value is set, the value will be the minimum value set for the z-domain in the Environment Settings dialog box. If there is no z-domain set in the Environment Settings dialog box, the z-value will be taken from the minimum value set for the z-domain of the input. If the input does not contain a z-domain, zero is used as the z-value.
Z-values, such as building heights, can be represented on the z-axis in a three-dimensional x,y,z coordinate system. If you want your feature class outputs to be able to store z-values for each vertex, you must specify this before running a tool. Z-values can't subsequently be added.
The default (Same As Input) takes the state of the input data to a tool—if the input can store z-values, the output will also be able to store z-values. By setting the option to Enabled, output feature classes will be able to store z-values, regardless of whether the input data to a tool can. By setting the option to Disabled, outputs from tools won't be able to store z-values, even if the input to a tool can.
If you set this option to Enabled or Same As Input, the z-values applied to each vertex in the output will be based on the input if they are present. If z-values are not present on the input and there is no value set for the default output z-value in the Environment Settings dialog box, the minimum value in the z-domain is used as the z-value. If there is no z-domain in the input, zero is given as the z-value.
M-values on polylines are used in linear referencing to imply a route measure. Route measures can be used to represent a location along a route, such as mileages along a highway. If you want your output feature classes to be able to store m-values for each vertex, you must specify this before running a tool. The ability to store m-values can't be subsequently added.
The default (Same As Input) takes the state of the input data to a tool—if the input can store m-values, the output will also be able to store m-values. By setting the option to Enabled, output feature classes will be able to store m-values, whether or not the input data to a tool can. By setting the option to Disabled, outputs from tools won't be able to store m-values, even if the input data can.
If you set this option to Enabled or Same As Input, the m-values applied to each vertex in the output will be based on the input if they are present, unless the tool will set or reset measure values, in which case input measures will be ignored and new ones will be calculated. If m-values are not present in the input, they will be set to Not a Number (NaN).
By specifying an extent, you define the area of interest for results from running tools.
In the case of feature data, all input features to a tool that pass through the area of interest will be included in the calculation.
For raster data, results from running tools will be contained within the extent set.
The extent is a rectangle, specified by identifying the coordinates of the window in map space.
The default extent is set to Default. With this extent set, the tool determines the extent of the output based on the extent of the input.
Setting a snap raster ensures that the cell alignment of the analysis extent will match accurately with an existing raster. This is done by snapping the lower-left corner of the specified analysis extent to the lower-left corner of the nearest cell in the snap raster and snapping the upper-right corner of the specified analysis extent to the upper-right corner of the nearest cell in the snap raster.
Help for M resolution and tolerance can be found in the following links:
M Resolution and M Tolerance contain details on these environment settings.
Feature class basics contains a discussion of M resolution and tolerance.
Help for XY resolution and tolerance can be found in the following links:
XY Resolution and M Tolerance contain details on these environment settings.
Feature class basics contains a discussion of XY resolution and tolerance.
Z Resolution and M Tolerance contains details on these environment settings.
Feature class basics contains a discussion of Z resolution and tolerance.
Help for random number generation can be found in the following links:
Random number generator contains details on this environment setting.
See Random number generators and streams for conceptual help on this topic.
NOTE: Cluster tolerance is only applicable with ArcGIS 9.1 or earlier. Starting with ArcGIS 9.2, XY tolerance replaces cluster tolerance.
# Import system modules and create the Geoprocessor object
import sys, string, os, arcgisscripting
gp = arcgisscripting.create()
# Demonstrate the relationship between cluster tolerance and XY tolerance.
# At version 9.2, XY tolerance replaces cluster tolerance. They are
# equivalent. However, cluster tolerance has been phased out, and you
# will not see it in the list of environment settings, but it is
# still available in scripting to maintain backward compatibility with
# scripts written at 9.1.
# Print the passed down environment values of cluster and XY tolerance
gp.AddMessage(" ")
gp.AddMessage("Passed down environments:")
gp.AddMessage("Cluster tolerance = %s" % gp.clustertolerance)
gp.AddMessage("XY tolerance = %s" % gp.xytolerance)
# Set cluster tolerance and print again. Both cluster tolerance and
# XY tolerance will be 999.9 inches
gp.AddMessage(" ")
gp.AddMessage("Setting cluster tolerance")
gp.clustertolerance = "999.9 inches"
# Now set the XY tolerance and print again. Both cluster tolerance and
# XY tolerance will be 888.8 inches
gp.AddMessage(" ")
gp.AddMessage("Setting XY tolerance")
gp.xytolerance = "888.8 inches"
