Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference
Licensing for geoprocessing tools
Release 9.2
Last modified November 9, 2006
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Geoprocessing tool reference"
Related Topics
The core toolboxes contain a mixture of tools available with specific license levels. These are shown
in the tables below. An 'x' represents the tool is available for that license level.
NOTE: The Coverage Tools toolbox is only available with an ArcInfo license. All tools provided with extensions are available at any license level.
3D Analyst tools
All 3D Analyst tools are available at all license levels (ArcView, ArcEditor, and ArcInfo) if you have the ArcGIS 3D Analyst extension.
Analysis tools
Toolset/Tool ArcView ArcEditor ArcInfo
Extract toolset
Clip x x x
Select x x x
Split
x
Table Select x x x
Overlay toolset
Erase
x
Identity
x
Intersect x x x
Spatial Join x x x
Symmetrical Difference
x
Union x x x
Update
x
Proximity toolset
Buffer x x x
Create Thiessen Polygons
x
Multiple Ring Buffer x x x
Near
x
Point Distance
x
Statistics toolset
Frequency
x
Summary Statistics x x x
Cartography tools
Graphic Quality toolset
Detect Graphic Conflict
x
Masking Tools toolset
Cul-de-Sac Masks
x
Feature Outline Masks
x
Intersecting Layers Masks
x
Representation Management toolset
Add Representation
x
Caculate Representation Rule
x
Drop Representation
x
Remove Override
x
Select Feature by Override
x
Set Layer Representation
x
Update Override
x
Symbolization Refinement toolset
Align Marker to Stroke or Fill
x
Calculate Geodesic Angle
x
Calculate Line Caps
x
Calculate Polygon Main Angle
x
Create Overpass
x
Create Underpass
x
Set Presentation Control Points by Angle
x
Conversion tools
From Raster toolset
Raster to ASCII x x x
Raster to Float x x x
Raster to Point x x x
Raster to Polygon x x x
Raster to Polyline x x x
Metadata toolset
ESRI Metadata Translator x x x
Metadata Publisher x x x
USGS MP Metadata Translator x x x
XSLT Transformation x x x
To CAD toolset
Add CAD Fields
x
Create CAD XData
x
Export to CAD
x
Set CAD Alias
x
To Coverage toolset
Feature Class to Coverage
x
To dBase toolset
Table to dBase (multiple) x x x
To Geodatabase toolset
Feature Class to Feature Class x x x
Feature Class to Geodatabase (multiple) x x x
Import CAD Annotation x x x
Import Coverage Annotation x x x
Import from CAD x x x
Raster to Geodatabase (multiple) x x x
Table to Geodatabase (multiple) x x x
Table to Table x x x
To Raster toolset
ASCII to Raster x x x
DEM to Raster x x x
Feature to Raster x x x
Float to Raster x x x
Point to Raster
NOTE: This tool is available with an ArcView or ArcEditor license, if the Spatial Analyst extension or the 3D Analyst extension is installed.
x
Polygon to Raster
x
Polyline to Raster
x
Raster to Other Format (multiple) x x x
To Shapefile toolset
Feature Class to Shapefile (multiple) x x x
Coverage tools
All Coverage tools require an ArcInfo license. No Coverage tools are available with an ArcView or ArcEditor license.
Data Interoperability tools
All Data Interoperability tools are avaliable at all license levels—ArcView, ArcEditor, and ArcInfo—if you have the ArcGIS Data Interoperability extension.
Data Management tools
Data Comparison toolset
Feature Compare x x x
File Compare x x x
Raster Compare x x x
Table Compare x x x
TIN Compare x x x
Database toolset
Compact x x x
Compress
x x
Upgrade Spatial Reference x x x
Disconnected Editing toolset
Check In x x x
Check In from Delta
x x
Check Out x x x
Export to Delta
x x
Distributed Geodatabase toolset
Add Global IDs
x x
Compare Replica Schema
x x
Create Replica
x x
Create Replica Footprints
x x
Export Acknowledgement Message
x x
Export Data Change Message
x x
Export Replica Schema
x x
Import Message
x x
Import Replica Schema
x x
Re-Export Unacknowledged Messages
x x
Synchronize
x x
Domains toolset
Add Coded Value to Domain x x x
Assign Domain to Field x x x
Create Domain x x x
Delete Coded Value from Domain x x x
Delete Domain x x x
Domain to Table x x x
Remove Domain from Field x x x
Set Value for Range Domain x x x
Table to Domain x x x
Feature Class toolset
Append Annotation Feature Classes x x x
Calculate Default Cluster Tolerance x x x
Calculate Default Spatial Grid Index x x x
Create Feature Class x x x
Create Fishnet x x x
Create Random Points
x
Integrate x x x
Update Annotation Feature Class x x x
Features toolset
Add XY Coordinates x x x
Adjust 3D Z x x x
Check Geometry x x x
Copy Features x x x
Delete Features x x x
Feature Envelope to Polygon
x
Feature to Line
x
Feature to Point
x
Feature to Polygon
x
Feature Vertices to Points
x
Multipart to Singlepart x x x
Polygon to Line
x
Repair Geometry x x x
Split Line at Vertices
x
Fields toolset
Add Field x x x
Assign Default to Field x x x
Calculate End Date x x x
Calculate Field x x x
Delete Field x x x
Transpose Time Fields x x x
File Geodatabase toolset
Compress File Geodatabase Data x x x
Uncompress File Geodatabase Data x x x
General toolset
Append x x x
Calculate Value
x
Copy x x x
Delete x x x
Merge x x x
Merge Branch x x x
Rename x x x
Select Data x x x
Generalization toolset
Aggregate Polygons
x
Collapse Dual Lines to Centerline
x
Dissolve x x x
Eliminate
x
Simplify Building
x
Simplify Line
x x
Simplify Polygon
x
Smooth Line
x x
Indexes toolset
Add Attribute Index x x x
Add Spatial Index x x x
Remove Attribute Index x x x
Remove Spatial Index x x x
Joins toolset
Add Join x x x
Remove Join x x x
Layers and Table Views toolset
Make Feature Layer x x x
Make Query Table x x x
Make Raster Catalog Layer x x x
Make Raster Layer x x x
Make Table View x x x
Make XY Event Layer x x x
Save to Layer File x x x
Select Layer by Attribute x x x
Select Layer by Location x x x
Projections and Transformations toolset
Create Custom Geographic Transformation x x x
Define Projection x x x
Feature toolset
Batch Project x x x
Create Spatial Reference x x x
Project x x x
Raster toolset
Flip x x x
Mirror x x x
Project Raster x x x
Rescale x x x
Rotate x x x
Shift x x x
Warp x x x
Raster toolset
Add Colormap x x x
Batch Build Pyramids x x x
Batch Calculate Statistics x x x
Build Raster Attribute Table x x x
Clip x x x
Composite Bands x x x
Copy Raster x x x
Copy Raster Catalog Items x x x
Create Ortho Corrected Raster Dataset x x x
Create Pan-sharpened Raster Dataset x x x
Create Random Raster
x
Create Raster Catalog x x x
Create Raster Dataset x x x
Delete Colormap x x x
Delete Raster Attribute Table x x x
Delete Raster Catalog Items x x x
Get Raster Properties x x x
Mosaic x x x
Mosaic to New Raster x x x
Resample x x x
Workspace to Raster Catalog x x x
Workspace to Raster Dataset x x x
Relationship Classes toolset
Create Relationship Class
x x
Table to Relationship Class
x x
Subtypes toolset
Add Subtype
x x
Remove Subtype
x x
Set Default Subtype
x x
Set Subtype Field
x x
Table toolset
Analyze
x x
Change Privileges
x x
Copy rows x x x
Create Table x x x
Delete Rows x x x
Get Count x x x
Pivot Table
x
Topology toolset
Add Feature Class to Topology
x x
Add Rule to Topology
x x
Create Topology
x x
Remove Feature Class from Topology
x x
Remove Rule from Topology
x x
Set Cluster Tolerance
x x
Validate Topology
x x
Versions toolset
Alter Version
x x
Create Version
x x
Delete Version
x x
Post Version
x x
Reconcile Version
x x
Register as Versioned
x x
Unregister as Versioned
x x
Workspace toolset
Create ArcInfo Workspace
x
Create Feature Dataset x x x
Create File GDB x x x
Create Folder x x x
Create Personal GDB x x x
Geocoding tools
Create Address Locator x x x
Geocode Addresses x x x
Rebuild Address Locator x x x
Rematch Addresses x x x
Standardize Addresses x x x
Geostatistical Analyst tools
All Geostatistical Analyst tools are avaliable at all license levels—ArcView, ArcEditor, and ArcInfo—if you have the ArcGIS Geostatistical Analyst extension.
Linear Referencing tools
Calibrate Routes x x x
Create Routes x x x
Dissolve Route Events x x x
Locate Features Along Routes x x x
Make Route Event Layer x x x
Overlay Route Events x x x
Transform Route Events x x x
Military Analyst tools
All Military Analyst tools are avaliable at all license levels—ArcView, ArcEditor, and ArcInfo—if you have the ArcGIS Military Analyst extension.
MOLE tools
All Military Overlay Editor (MOLE) tools are avaliable at all license levels—ArcView, ArcEditor, and ArcInfo—if you have the ArcGIS Military Overlay Editor (MOLE) extension.
Multidimension tools
Feature to NetCDF x x x
Make NetCDF Feature Layer x x x
Make NetCDF Raster Layer x x x
Make NetCDF Table View x x x
Raster to NetCDF x x x
Select by Dimension x x x
Table to NetCDF x x x
Network Analyst tools
All Network Analyst tools are avaliable at all license levels—ArcView, ArcEditor, and ArcInfo—if you have the ArcGIS Network Analyst extension.
Server tools
Delete Globe Server Cache x x x
Delete Map Server Cache x x x
Generate Globe Server Cache x x x
Generate Map Server Cache x x x
Generate Map Server Cache Tiling Scheme x x x
Update Globe Server Cache x x x
Update Map Server Cache x x x
Spatial Analyst tools
All Spatial Analyst tools are avaliable at all license levels—ArcView, ArcEditor, and ArcInfo—if you have the ArcGIS Spatial Analyst extension.
Spatial Statistics tools
Toolset/tool ArcView ArcEditor ArcInfo
Analyzing Patterns toolset
Average Nearest Neighbor x x x
High/Low Clustering (Getis-Ord general G) x x x
Multi-Distance Spatial Cluster Analysis (Ripley's K Function) x x x
Spatial Autocorrelation (Morans I) x x x
Mapping Clusters toolset
Cluster and Outlier Analysis (Anselin Local Morans I) x x x
Cluster/Outlier Analysis with Rendering x x x
Hot Spot Analysis (Getis-Ord Gi*) x x x
Hot Spot Analysis with Rendering x x x
Measuring Geographic Distributions toolset
Central Feature x x x
Directional distribution (Standard Deviational Ellipse) x x x
Linear Directional Mean x x x
Mean Center x x x
Standard Distance x x x
Utilities toolset
Calculate Areas x x x
Calculate Distance Band from Neighbor Count x x x
Collect Events x x x
Collect Events with Rendering x x x
Count Rendering x x x
Export Feature Attribute to ASCII x x x
Z Score Rendering x x x
Tracking Analyst tools
All Tracking Analyst tools are avaliable at all license levels—ArcView, ArcEditor, and ArcInfo—if you have the ArcGIS Tracking Analyst extension.
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
