Field Check script |
Release 9.2
Last modified November 9, 2006 |
# Description:
# Tests if a field exists and outputs two booleans:
# Exists - true if the field exists, false if it doesn't exist
# Not_Exists - true if the field doesn't exist, false if it does exist
# (the logical NOT of the first output).
# Arguments:
# 0 - Table name
# 1 - Field name
# 2 - Exists (boolean - see above)
# 3 - Not_Exists (boolean - see above)
# Created by: ESRI
# Standard error handling - put everything in a try/except block
try:
# Import system modules
import sys, string, os, arcgisscripting
# Create the Geoprocessor object
gp = arcgisscripting.create()
# Get input arguments - table name, field name
in_Table = gp.GetParameterAsText(0)
in_Field = gp.GetParameterAsText(1)
# First check that the table exists
if not gp.Exists(in_Table):
raise Exception, "Input table does not exist"
# Use the ListFields function to return a list of fields that matches
# the name of in_Field. This is a wildcard match. Since in_Field is an
# exact string (no wildcards like "*"), only one field should be returned,
# exactly matching the input field name.
fields = gp.ListFields(in_Table, in_Field)
# If ListFields returned anything, the Next operator will fetch the
# field. We can use this as a Boolean condition.
field_found = fields.Next()
# Branch depending on whether field found or not. Issue a
# message, and then set our two output variables accordingly
if field_found:
gp.AddMessage("Field %s found in %s" % (in_Field, in_Table))
gp.SetParameterAsText(2, "True")
gp.SetParameterAsText(3, "False")
else:
gp.AddMessage("Field %s not found in %s" % (in_Field, in_Table))
gp.SetParameterAsText(2, "False")
gp.SetParameterAsText(3, "True")
# Handle script errors
except Exception, errMsg:
# If we have messages of severity error (2), we assume a GP tool raised it,
# so we'll output that. Otherwise, we assume we raised the error and the
# information is in errMsg.
if gp.GetMessages(2):
gp.AddError(GP.GetMessages(2))
else:
gp.AddError(str(errMsg))
