Bipolar Oblique Conformal Conic |
Release 9.2
Last modified August 3, 2007 |
![]() ![]() ![]() Print all topics in : "Supported map projections" |
This projection was developed specifically for mapping North and South America. It maintains conformality. It is based on the Lambert Conformal Conic, using two oblique conic projections side by side.
Learn more about the Lambert Conformal Conic projection
Two oblique conics are joined with the poles 104° apart. A great circle arc 104° long begins at 20° S and 110° W, cuts through Central America, and terminates at 45° N and approximately 19°59'36" W. The scale of the map is then increased by approximately 3.5 percent. The origin of the coordinates is 17°15' N, 73°02' W (Snyder, 1993).
The two oblique cones are each conceptually secant. These standard lines do not follow any single parallel or meridian.
Only from each transformed pole to the nearest actual pole.
Specialized for displaying North and South America only together. The Bipolar Oblique projection will display North America and South America only. If having problems, check all feature types (particularly annotation and tics) and remove any features that are beyond the range of the projection.
Developed in 1941 by the American Geographical Society as a low-error single map of North and South America.
Conformal mapping of North and South America as a contiguous unit.
Used by USGS for geologic mapping of North America until it was replaced in 1979 by the Transverse Mercator projection.
Learn more about the Transverse Mercator projection
