Show Navigation | Hide Navigation
You are here:
Extensions > 3D Analyst > Getting started with 3D Analyst
ArcGlobe 3D display environment
Release 9.2
Last modified February 29, 2008
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Getting started with 3D Analyst"
Related Topics
ArcGlobe is a 3D visualization application that allows you to view large amounts of GIS data on a globe surface.
ArcGlobe provides a new and unique way to view and analyze your GIS data. Spatially referenced data is placed on a 3D globe surface, displayed in its true geodetic location. You can manipulate the globe, then investigate and analyze its data while viewing the globe as a whole or regions within it. You can view data covering a global extent and seamlessly zoom in to highly detailed, localized data. ArcGlobe gives you the power to tame voluminous data while fully employing all information the data can give you. ArcGlobe allows efficient display and query of raster data, and it is integrated to function with the ArcGIS geodatabase while providing support for analysis in the geoprocessing environment.
ArcGlobe ships with a comprehensive set of imagery on DVD, including elevation data for the entire earth. To help you get started and to provide a backdrop for the layers you'll add, ArcGlobe will open with a set of default layers. Then, depending on how you want to use ArcGlobe, the default layers can be changed, replaced with others, or completely removed.
Much of the functionality of ArcGlobe is shared with the ArcScene 3D display environment, though there are several key differences between the two 3D environments.
Common tasks performed in ArcGlobe include:
Common Task Where to go for more information
Creating an ArcGlobe document About creating 3D views
Creating a 3D document
About 3D symbology
Setting the role of a 3D layer
Saving an ArcGlobe document Saving a 3D document
Printing an ArcGlobe document Printing a 3D document
Exporting an ArcGlobe document Exporting a 3D document
Generating 3D data Creating 3D feature data
Converting 2D features to 3D features
About geoprocessing with 3D Analyst
Using 2D data in ArcGlobe Displaying 2D features in ArcGlobe
Navigating in 3D About 3D navigation
3D navigation concepts
About 3D navigation tools
Creating a 3D animation Creating 3D animations
An overview of animation
Optimizing ArcGlobe Optimizing ArcGlobe
Optimizing ArcGlobe layers Optimizing raster and surface layers
Optimizing 3D multipatch layers
Using cache consolidation in ArcGlobe
Managing the ArcGlobe cache Caching in ArcGlobe
Cache management in ArcGlobe
Serving an ArcGlobe document Guidelines for creating 3D views for GlobeServer
Visualizing 3D data
3D Analyst allows you to drape images or vector data over surfaces and extrude vector features from a surface to create lines, walls, and solids. You can use 3D symbols to add realism to the display of your GIS data and create high-quality animations to distribute the results.
You can view a scene from multiple viewpoints using different viewers or change the properties of 3D layers to use shading or transparency.
You can change the properties of a 3D globe to set:
The world with sun lighting City view in ArcGlobe
Analyzing 3D data
All the ArcGIS 3D Analyst geoprocessing tools are available to you in ArcGlobe. The tools can be run from the geoprocessing window, a few examples include:
You can develop advanced geoprocessing models in the ModelBuilder window, then run them directly from ArcGlobe.
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
