Show Navigation | Hide Navigation
You are here:
Editing and data compilation > Creating new features
About creating new features
Release 9.2
Last modified August 17, 2007
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Creating new features"
Related Topics
To create a new feature in ArcMap, you create an edit sketch. A sketch is composed of vertices (the positions that define the shape of a line or polygon feature) and segments (the lines that connect the vertices). You create a sketch using the sketch construction tools located on the Editor toolbar tool palette.
Explore the tools on the tool palette
Current Task list
You can use a sketch to complete various tasks; these are listed in the Current Task drop-down list shown below.
Current Task dropdown list
To create a new feature, click Create New Feature from the drop-down list. When the current task setting is Create New Feature, what you digitize becomes a new feature in your target layer.
Other tasks you can complete with a sketch and a task include modifying, extending, trimming, and reshaping features.
Target layer list
The type of feature you create is determined by the setting of the Target layer drop-down list. This list contains the names of all the layers in the workspace (the geodatabase or folder of shapefiles) with which you're working, as well as any subtypes. For instance, if you set the target layer to Buildings: Commercial, any features you create will be part of the Commercial subtype of the Buildings layer.
Target Layer dropdown list
Sketch construction tools
The Sketch tool Sketch is the main tool you use to create a sketch. To create point features, click once on the map. To create line or polygon features, use the Sketch tool to digitize the vertices that make up that feature. To create the last vertex and finish the sketch, double-click the mouse. After you finish the sketch, ArcMap adds the final segment of the sketch, and the sketch turns into a feature. There are several other tools you can use to create a sketch. The Sketch tool and the other tools are found on the Editor toolbar tool palette.
Sketch tools palette
Click here to see the tools and examples of how they might be used to create features.
Sketch tool context menu
When using the Sketch tool, you can access the Sketch tool context menu by right-clicking away from the sketch you're creating. The menu has options for placing the vertices and segments specifically where you want them. For example, you can set a segment to be a certain length or angle or create a vertex at a specific x,y coordinate location.
Click here to see the Sketch tool's context menu, and learn how you can enhance your productivity while editing.
Methods for creating points, vertices, and segments of features
You can use any combination of the following methods for creating points, vertices, or segments to create a new line or polygon feature:
Sketch context menu
ArcMap has another context menu—the Sketch context menu—that works more directly with the sketch as a whole. With this menu, you can:
From the Properties dialog box, you can remove parts from a multipart feature, remove many vertices in one operation, add vertices, or modify m-values and z-values.
The Sketch context menu is available when you right-click while the pointer is positioned over any part of the sketch using any tool.
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
