Show Navigation | Hide Navigation
You are here:
Editing and data compilation > Editing topology
Creating a map topology
Release 9.2
Last modified August 17, 2007
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Editing topology"
Related Topics
About creating a map topology
A map topology is a simple topology that you can impose upon simple features on a map during an edit session. Although you can't create or edit geodatabase topologies with ArcView (only ArcEditor and ArcInfo), you can create and edit map topologies in ArcView.
A map topology allows you to simultaneously edit simple features that overlap or touch each other in ArcMap. You can use the Topology Edit tool Topology Edit tool on the Topology toolbar and the Modify Edge and Reshape Edge edit tasks to edit the features in a map topology. The features can be in one or more feature classes and may have different geometries. Line features and the outlines of polygon features become topological edges when you create a map topology. Point features, the endpoints of lines, and the places where edges intersect become nodes.
A map topology can be applied to simple features in a shapefile or to simple feature classes in a geodatabase. The feature classes that participate in the map topology must be in the same folder or geodatabase. A map topology cannot be applied to feature classes that participate in a geometric network.
A map topology creates topological relationships between the parts of features that are coincident. You can specify the feature classes that you want to participate in the map topology. You can also choose the distance, or cluster tolerance, that defines how close together edges and vertices must be in order to be considered coincident. When you create a map topology, the cluster tolerance that you specify is used to determine which parts of the features are coincident and which edges and nodes in the topology are shared. The cluster tolerance is typically a small actual ground distance. Setting large cluster tolerances can result in features being collapsed or distorted when vertices with a given feature snap together.
There are two steps to creating a map topology:
  1. Specify which feature classes on the map will participate in the topology.
  2. Specify a cluster tolerance. The cluster tolerance is a distance within which features will be coincident.
When you have defined a map topology, it is shown on the Topology toolbar in the Topology drop-down list as an entry called <Map Layers>. Only one map topology can be defined for an edit session.
Map topology versus geodatabase topology
Geodatabase topology is a data object created and stored in a geodatabase. A geodatabase topology defines a set of rules about the relationships between feature classes in a feature dataset. Geodatabase topology is created in ArcCatalog and can be added to ArcMap as a layer, just like any other data. After editing has been performed on the feature classes, you validate the geodatabase topology to see if the edits break any of the topology's rules. Any errors can be fixed or marked as exceptions. An ArcEditor or ArcInfo license is required to create, edit, or validate geodatabase topology. To use geodatabase topology when you edit data from a geodatabase, the geodatabase topology in which the data participates must be in your map. If you are using an ArcView license, you can open a map containing a geodatabase topology, but you cannot start an edit session on feature classes that participate in a geodatabase topology.
Map topology is temporary and only lasts for the duration of your edit session. Unlike geodatabase topologies, map topologies are not stored permanently or represented as layers in the map. Map topologies have no rules and there is no validation process. The tools and commands for validating topology and fixing errors are disabled in the Topology toolbar when you work with a map topology. In previous versions of ArcGIS, map topology functionality was invoked using the Integrate command. This command has been replaced with the Map Topology command.
When to use a map topology
Map topology is useful because it enables you to perform topological editing in situations where you can't use geodatabase topology:
Editing a map topology
After you create a map topology, you can use the Topology Edit tool to edit the edges and nodes shared by the features. Editing an edge or node shared by two or more different features results in each feature being modified. This lets you move a border to update two forest polygons or move a corner vertex and update several parcel polygons and a few lot boundaries at the same time.
You do not specify any topology rules for a map topology. All edges or vertices of features in the map topology that fall within the cluster tolerance are considered to be topologically shared. You edit shared edges and vertices in a map topology in the same way and with the same tools as you would edit a geodatabase topology. Since there are no topology rules, there is no need to validate a map topology, and there is no creation of error features.
At the geometry level, topologies are about simple relationships—such as coincidence, covering, and crossing—between the geometric primitives that make up features. While all simple feature class geometries (point, line, polygon) may participate in topologies internally, the types of geometry that are acted on when editing a topology are:
Learn more about editing features in a topology
Learn more about editing shared geometry
How to create a map topology
  1. On the Editor toolbar, click the Editor menu and click Start Editing.
  2. If prompted, click the source folder or geodatabase that contains the data you want to edit and click OK.
  3. Click the Map topology button Map Topology button on the Topology toolbar.
  4. Check the feature classes that will participate in the map topology.
  5. All the layers in your current edit session that can participate in the map topology are listed in the dialog box. Layers representing annotation and dimension feature classes and feature classes that participate in a geometric network cannot be included in a map topology and won't be listed.
  6. Optionally, set a cluster tolerance for the map topology.
  7. The default cluster tolerance is the minimum possible cluster tolerance. Increasing the cluster tolerance may cause more features to be snapped together and considered coincident, but this may reduce the spatial accuracy of your data.
  8. Click OK.
  9. Click the Topology Edit tool Topology Edit tool and click the features you want to edit using the map topology.
  10. The map topology is created for the features that are visible in the current display extent.
Editing features in a map topology
  1. See Editing features in a topology or Editing shared geometry.
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
