Show Navigation | Hide Navigation
You are here:
Map projections and coordinate systems > Getting started with map projections
Projection basics the GIS professional needs to know
Release 9.2
Last modified November 9, 2006
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Getting started with map projections"
Related Topics
Coordinate systems, also known as map projections, are arbitrary designations for spatial data. Their purpose is to provide a common basis for communication about a particular place or area on the earth's surface. The most critical issue in dealing with coordinate systems is knowing what the projection is and having the correct coordinate system information associated with a dataset. There are two types of coordinate systems—geographic and projected.
A geographic coordinate system uses a three-dimensional spherical surface to define locations on the earth. It includes an angular unit of measure, a prime meridian, and a datum (based on a spheroid). In a geographic coordinate system a point is referenced by its longitude and latitude values. Longitude and latitude are angles measured from the earth's center to a point on the earth's surface. The angles often are measured in degrees (or in grads).
Learn more about geographic coordinate systems
A projected coordinate system is defined on a flat, two-dimensional surface. Unlike a geographic coordinate system, a projected coordinate system has constant lengths, angles, and areas across the two dimensions. A projected coordinate system is always based on a geographic coordinate system that is based on a sphere or spheroid.
In a projected coordinate system, locations are identified by x,y coordinates on a grid, with the origin at the center of the grid. Each position has two values that reference it to that central location. One specifies its horizontal position and the other its vertical position.
Learn more about projected coordinate systems
When the first map projections were devised, it was assumed, incorrectly, that the earth was flat. Later the assumption was revised, and the earth was assumed to be a perfect sphere. In the 18th century, people began to realize that the earth was not perfectly round. This was the beginning of the concept of the cartographic spheroid.
To more accurately represent locations on the earth's surface, map makers studied the shape of the earth (geodesy) and created the concept of the spheroid. A datum links a spheroid to a particular portion of the earth's surface. Recent datums are designed to fit the entire earth's surface well.
The most commonly used datums in North America are:
Newer spheroids are developed from satellite measurements and are more accurate than those developed in the 19th and early 20th centuries.
You will find that the terms 'geographic coordinate system' and 'datum' are used interchangeably.
Learn more about datums
The coordinates for a location will change depending on the datum and spheroid on which those coordinates are based, even if using the same map projection and projection parameters.
For example, the geographic coordinates below are for the city of Bellingham, Washington using 3 different datums:
Datum Longitude Latitude
NAD 1927 -122.466903686523 48.7440490722656
NAD 1983 -122.46818353793 48.7438798543649
WGS 1984 -122.46818353793 48.7438798534299
A principal of good data management is to obtain the coordinate system information from the data source providing the data. Do not guess about the coordinate system of data because this will result in an inaccurate GIS database. The necessary parameters are the following:
Geographic coordinate system (Datum)
Unit of measure
Zone (for UTM)
FIPS zone (for State Plane)
Projection parameters
Projection parameters may be required, depending on the map projection. For example, the Albers and Lambert projections require the following parameters:
1st standard parallel
2nd standard parallel
Central meridian
Latitude of origin
False easting
False northing
Unit of measure
You can define a coordinate system for data using the following options:
If the data has a coordinate system definition, but it does not match the typical coordinate system used by an organization, you can reproject the data. You can reproject data using the following tools:
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
