An overview of coverage settings |
Release 9.2
Last modified October 30, 2007 |
![]() ![]() ![]() Print all topics in : "Environment categories" |
The environment settings in the Coverage Settings section of the Environment Settings dialog box apply to coverage tools only. The default values for the following settings can be changed: the precision for new or derived coverages and the level of comparison between projection files.
The following subtopics supplement the reference topics found in Environment settings.
Before running coverage tools, you can set the degree of similarity between input projection files required for a match to occur. Use this option if you want to validate the input projections before running coverage tools.
The following settings are available:
Before you begin using tools in the Coverage Tools toolbox, you should determine what the precision of your output coverages should be.
New coverages are those that are created—for example, using the Create Coverage tool. Derived coverages are those that are derived from tools that accept input data to derive the output coverage—for example, coverages created by running the Buffer tool.
The default precision is set to SINGLE for new coverages that are created and HIGHEST for derived coverages. If you want new coverages that are created to be in double precision, set the Precision For New Coverages to DOUBLE. If you always want derived coverages to be in double precision, regardless of the precision of the input data, set the Precision For Derived Coverages to DOUBLE.
Learn more about coverage precision
