Exporting image services in MapInfo |
Release 9.3
Last modified June 25, 2010 |
The image data you receive as a client from an image service can be exported as a raster dataset and saved on your local system. You may need to save this data to use it in analysis applications. You cannot export the raw data used to create the service; you can only export the data you receive as a client—that is, the processed raster data. You can save this data into TIFF, JPEG 2000, and JPEG file formats.
| Field | Description |
| Set the extent to |
| Extents |
| Width | Width of the exported image, expressed in the units of the data frame. |
| Height | Height of the exported image, expressed in the units of the data frame. |
| Columns | Number of columns of pixels in the exported image. |
| Rows | Number of rows of pixels in the exported image. |
| Ground Pixel Size X | Size of pixels at ground level in the x direction. |
| Ground Pixel Size Y | Size of pixels at ground level in the y direction. |
| Format | Format of the exported image. You can choose TIFF/TFW no compression, TIFF/TFW-JPEG, TIFF/TFW-LZ77, JPEG, JP2, and PNG. |
| Tile Size | Size of internal tiles in the exported image for TIFF images only. |
| Compression Quality | Quality of compression. A compression quality of 100 percent is the best |
| Approx. MB | Approximate size of the image in megabytes. This is a read-only field. |
| File Name | Path and name of the exported image. By default, the name is "Untitled". |
