ResetProgressor method |
Release 9.3
Last modified January 19, 2010 |
Print all topics in : "Properties and Methods" |
This topic was updated for 9.3.1.
Resets the progressor to its initial settings
For use with script tools
NOTE: Supported only when the geoprocessor is instantiated using the arcgisscripting module; not supported when using the win32com module. Learn more about creating the geoprocessor object
| Part | Description |
| object | The instantiated geoprocessing object |
import arcgisscripting
gp = arcgisscripting.create(9.3)
# Allow overwriting of output
gp.OverWriteOutput = 1
# Set current workspace
gp.Workspace = "c:/temp"
# Get a list of shapefiles in folder
fcs = gp.ListFeatureClasses()
# Find the total count of shapefiles in list
fcCount = len(fcs)
# Set the progressor
gp.SetProgressor("step", "Copying shapefiles to geodatabase...", 0, fcCount, 1)
# Create a file gdb to contain new feature classes
gp.CreateFileGDB(gp.workspace, "fgdb.gdb")
# For each shapefile, copy to a file geodatabase
for shp in fcs:
# Strip the '.shp' extension
fc = shp.rstrip(".shp")
# Update the progressor label for current shapefile
gp.SetProgressorLabel("Loading " + shp + "...")
# Copy the data
gp.CopyFeatures(shp, "fgdb.gdb/" + fc)
# Update the progressor position
gp.SetProgressorPosition()
gp.ResetProgressor()
