ValidateFieldName method |
Release 9.3
Last modified January 19, 2010 |
Print all topics in : "Properties and Methods" |
This topic was updated for 9.3.1.
Takes a string (field name) and a workspace path and returns a valid field name based on name restrictions in the output geodatabase. All invalid characters in the input string will be replaced with an underscore (_). The field name restrictions depend on the specific database used (Structured Query Language [SQL] or Oracle).
| Part | Description |
| object | The instantiated geoprocessing object |
| inputFieldName | The field name to be validated |
| Workspace | Optional. The workspace in which the field can be found |
# Create a new numeric field containing the ratio of polygon area to
# polygon perimeter. Two arguments, a feature class and field name,
# are expected.
import arcgisscripting
import os
gp = arcgisscripting.create(9.3)
# Check the number of arguments.
if len(sys.argv) < 2:
print "Script requires two arguments, feature class and field name"
else:
try:
# Get the input feature class and make sure it contains polygons.
input = sys.argv[1]
dsc = gp.Describe(input)
if dsc.ShapeType != "polygon":
raise "ShapeError"
# Get the new field name and validate it.
fieldname = sys.argv[2]
fieldname = gp.ValidateFieldName(fieldname, os.path.dirname(input))
# Make sure shape_length and shape_area fields exist
if len(gp.ListFields(input,"Shape_area")) > 0 and len(gp.ListFields(input,"Shape_length")) > 0:
# Add the new field and calculate the value.
gp.AddField(input, fieldname, "double")
gp.CalculateField(input,fieldname, "[Shape_Area] / [Shape_Length]")
else:
raise "FieldError"
except "ShapeError":
print "Input does not contain polygons"
except "FieldError":
print "Input does not shape area and length fields"
except:
print gp.GetMessages(2)
