Repair Geometry (Data Management) |
Release 9.3
Last modified March 8, 2012 |
Print all topics in : "Tools" |
NOTE: This topic was updated for 9.3.1.
Inspects each feature's geometry for problems and fixes the problems that are found. Valid input formats are shapefile and feature classes stored in a personal geodatabase or file geodatabase. For more information, see Checking and repairing geometries.
ArcSDE geodatabases automatically check each geometry's validity when it is uploaded; therefore, the Check and Repair Geometry tools are not for use with ArcSDE geodatabases.
Usage tips
This tool uses the same logic as the Check Geometry tool, but when a geometry problem is discovered, the relevant fix (listed below) is applied.
This is the list of geometry problems and the fix that is applied by this tool:
After applying one of the repairs above, the tool will reevaluate the feature's geometry to see if it still has problems; if another problem is discovered, another repair will be performed immediately on that feature. This can lead to more than one fix being applied to a single feature.
Line features that are M aware will not be modified (repaired) for any of the cases above with these exceptions:
The following environment settings affect this tool: Extent and workspace.
Command line syntax
An overview of the Command Line window
RepairGeometry_management <in_features> {DELETE_NULL | KEEP_NULL}
| Parameter | Explanation | Data Type |
| <in_features> |
The feature class or layer that will have feature geometry problems repaired. If a layer is specified and that layer has a selection, only the selected features will be repaired. Valid input formats are shapefile and feature classes stored in a personal geodatabase or file geodatabase. |
Feature Layer |
| {DELETE_NULL | KEEP_NULL} |
Specifies if action should be taken when features with NULL geometry are encountered.
Boolean |
RepairGeometry c:\myNewShapefiles\sketchy.shp"
Scripting syntax
About getting started with writing geoprocessing scripts
RepairGeometry_management (in_features, delete_null)
| in_features (Required) |
Feature Layer |
| delete_null (Optional) |
Boolean |
# RepairGeometryProblemList.py
# Description:
# Goes through the table generated by the Check Geometry tool. Runs the
# Repair Geometry tool on the features which were identified as having
# some geometry problem.
# Requirements: Python and the Python win32all extension
# Author: ESRI
# Date 1/1/2004
# Create the Geoprocessor
import arcgisscripting, os
gp = arcgisscripting.create()
# Table that was produced by Check Geometry tool
table = "c:/data/badg.mdb/fc"
# Create some variables
dict = {}
query = ""
fieldName = ""
# Loop through the table using a cursor
rows = gp.searchCursor(table)
row = rows.next()
while row:
# Get the class (feature class) for that row, as well as the Feature ID
fc = row.GetValue("CLASS")
fid = row.GetValue("FEATURE_ID")
if not fieldName:
# Determine which type feature class this is (Geodatabase or other) since how the field name
# in the query is different for each
fcType= gp.Describe(fc).DataType
fieldName = gp.ListFields(fc, "*","FID").Next().Name
if fcType == "FeatureClass":
fieldName = "[" + fieldName + "]" # For Geodatabase, wrap the field name in [ ]
elif fcType == "ShapeFile":
fieldName = '"' + fieldName + '"' # For ShapeFiles, wrap the field name in " "
else:
raise Exception, "Repair Geometry does not support this format " + fcType
# Create the query
if query:
query = query + " OR " + fieldName + " = " + str(fid)
else:
query = fieldName + " = " + str(fid)
prevFc = fc
row = rows.next()
# Since there could be more than 1 CLASS in the table, separate each CLASS and its
# associated query into entries in a Python dictionary
if row:
if fc <> row.GetValue("CLASS"):
dict[prevFc] = query
query = ""
fieldName = ""
else:
query = ""
fieldName = ""
# Destroy the cursor object now that we're done with it
del rows
# Now loop through the dictionary and Make a layer with a definition query (so the Repair
# Geometry is run only on those features with some problem) and run Repair Geometry on each.
for fc in dict:
try:
gp.MakeFeatureLayer(fc, os.path.basename(fc),dict[fc])
gp.RepairGeometry(fc, r"c:\junk\outy.shp")
except:
print "Problem encountered attempting to repair " + fc
print "FINISHED"
