About environment settings for raster data |
Release 9.3
Last modified November 12, 2009 |
Print all topics in : "Raster analysis and geoprocessing" |
This topic was updated for 9.3.1.
Environment settings include the general settings for parameters, such as the default workspace or output coordinate system, and specific settings for other data types or applications. Environment settings can be set at three levels: for the application you are working in so they apply to all tools, for a model so they apply to all processes within the model, or for a particular process within a model. You can set these before you begin using a tool or while setting up the parameters for the tool. There are two main groups of environment settings related to raster data: the Raster Analysis settings and the Raster Storage settings.
To learn more about environment settings, see Environment settings.
Settings contained here are general settings that are applicable to raster data results.
| Setting | Explanation |
| Snap Raster | A raster that is used to control the cell alignment of the analysis extent and thus of the output rasters. |
Settings contained here are applicable when working with ArcGIS Spatial Analyst tools that input or output a raster, either file or geodatabase.
| Settings | Explanation |
| Cell size | The output cell size, or resolution. The default output resolution, when a feature class is used as input, is the width or height (whichever is shorter) of the extent of the feature class divided by 250.
| Mask | Identifies those cells within the analysis extent that will be considered when performing an operation or a function. Setting an analysis mask means that processing will only occur on selected cells and that all other cells will be assigned values of NoData. |
Settings contained here are applicable to raster data outputs for Spatial Analyst tools and the Raster toolset.
| Pyramid | Specifies whether to create pyramids with the output raster. For pyramid levels, choose a number of -1 or higher. A value of 0 will not build any pyramids, and a value of -1 will automatically choose the correct number of pyramid layers to create. When pyramids are built for ArcSDE geodatabases, you must specify the pyramid resampling technique:
| Raster Statistics | The Statistics option enables you to build statistics for the output raster dataset created. A skip factor may be set and applied to all types of raster datasets except GRID.
| Compression | Specifies the compression type.
| Tile Size | Specifies the width and height of the desired tile size. The default is 128 x 128. |
