Is Null |
Release 9.3
Last modified September 7, 2011 |
Print all topics in : "Math Logical (Spatial Analyst)" |
Returns 1 if the input value is NoData and 0 for cells that are not, on a cell-by-cell basis within the Analysis window.
Learn more about how Is Null works
Illustration
OutRas = IsNull(InRas1)
IsNull_sa InRas1 OutRas
Usage tips
Command line and Scripting
Input values can be positive or negative.
The output value types are always integer. The values are either 1 or 0. Cells in the input that have a value are given 0 on the output. Cells that are NoData in the input are given a value of 1 on the output.
The following environment settings affect this tool:
Map Algebra
Learn more about how to specify the input raster dataset in the Map Algebra expression of Raster Calculator.
ArcObjects
The output from the ArcObjects method is a raster object.
Command line syntax
An overview of the Command Line window
IsNull_sa <in_raster> <out_raster>
| Parameter | Explanation | Data Type |
| <in_raster> |
The input being tested to identify the cells that are NoData (null). |
Composite Geodataset |
| <out_raster> |
The output raster. Where cell values in the input are NoData, the output value will be 1. If it is any other value, the output value will be 0. |
Raster Dataset |
IsNull_sa C:/data/ras_1 C:/data/final_1
Scripting syntax
About getting started with writing geoprocessing scripts
IsNull_sa (in_raster, out_raster)
| in_raster (Required) |
| out_raster (Required) |
Raster Dataset |
# IsNull_sample.py
# Description:
# Returns 1 for cells in the input raster that have a value of
# NoData, and 0 if they do not.
# Requirements: None
# Author: ESRI
# Date: Sept 6, 2005
# Import system modules
import arcgisscripting
# Create the Geoprocessor object
gp = arcgisscripting.create()
try:
# Set the input raster dataset
inRaster1 = "c:/data/ras_1"
# Set the output raster name
outRaster = "c:/data/final_1"
# Check out Spatial Analyst extension license
gp.CheckOutExtension("Spatial")
# Process: IsNull
gp.IsNull_sa(inRaster1, outRaster)
except:
# If an error occurred while running a tool, then print the messages.
print gp.GetMessages()
Map Algebra syntax
IsNull(<grid>)
| <grid> | An input integer or floating-point raster, or an expression resulting in a raster. |
isnull(ingrid1) isnull(-5.6 + ingrid1) isnull(ingrid1 + ingrid2) isnull(sin(ingrid1) * 4) + (focalsum(ingrid2))
ArcObjects syntax
ILogicalOp::IsNull (geoDataset As IGeoDataset) As IGeoDataset
| geoDataset | An input Raster, RasterDataset, RasterBand, or RasterDescriptor. |
' Create the RasterLogicalOp object
Dim pLogicalOp As ILogicalOp
Set pLogicalOp = New RasterMathOps
' Create the input raster object
Dim pInputDataset As IGeoDataset
' Calls function to open the input raster dataset from disk
Set pInputDataset = OpenRasterDataset("D:\SpatialData", "inputraster")
' Create the output dataset object
Dim pOutputDataset As IGeoDataset
' Calls the method
Set pOutputDataset = pLogicalOp.IsNull(pInputDataset)
