Writing geometries |
Release 9.3
Last modified June 3, 2010 |
Print all topics in : "Data properties and access when scripting" |
This topic was updated for 9.3.1.
Using insert and update cursors, scripts can create new features in a feature class or update existing ones. A script can define a feature by creating a point object, populating its properties, and placing it in an array. That array can then be used to set a feature's geometry. A single geometry part is defined by an array of points, so a multipart feature can be created from multiple arrays of points.
Below is an example of a file that may be processed by the script below:
1;-61845879.0968;45047635.4861 1;-3976119.96791;46073695.0451 1;1154177.8272;-25134838.3511 1;-62051091.0086;-26160897.9101 2;17365918.8598;44431999.7507 2;39939229.1582;45252847.3979 2;41170500.6291;27194199.1591 2;17981554.5952;27809834.8945 3;15519011.6535;11598093.8619 3;52046731.9547;13034577.2446 3;52867579.6019;-16105514.2317 3;17160706.948;-16515938.0553
# Create a new line feature class using a text file of coordinates.
# Each coordinate entry is semicolon delimited in the format of ID;X;Y
# Import native arcgisscripting module and other required modules
import arcgisscripting
import fileinput
import os
import string
# Create the geoprocessor object
gp = arcgisscripting.create(9.3)
gp.OverWriteOutput = 1
# Get the coordinate ascii file
infile = gp.GetParameterAsText(0)
# Get the output feature class
fcname = gp.GetParameterAsText(1)
# Get the template feature class
template = gp.GetParameterAsText(2)
try:
# Create the output feature class
gp.CreateFeatureClass(os.path.dirname(fcname),os.path.basename(fcname),
"Polyline", template)
# Open an insert cursor for the new feature class
cur = gp.InsertCursor(fcname)
# Create an array and point object needed to create features
lineArray = gp.CreateObject("Array")
pnt = gp.CreateObject("Point")
# Initialize a variable for keeping track of a feature's ID.
ID = -1
for line in fileinput.input(infile): # Open the input file
# set the point's ID, X and Y properties
pnt.id, pnt.x, pnt.y = string.split(line,";")
print pnt.id, pnt.x, pnt.y
if ID == -1:
ID = pnt.id
# Add the point to the feature's array of points
# If the ID has changed, create a new feature
if ID != pnt.id:
# Create a new row or feature, in the feature class
feat = cur.NewRow()
# Set the geometry of the new feature to the array of points
feat.shape = lineArray
# Insert the feature
cur.InsertRow(feat)
lineArray.RemoveAll()
lineArray.add(pnt)
ID = pnt.id
# Add the last feature
feat = cur.NewRow()
cur.InsertRow(feat)
fileinput.close()
del cur
except:
print gp.GetMessages(2)
In some cases, it is desirable to create new geometries based on the features of another feature class. This can be achieved by using SearchCursor and InsertCursor simultaneously.
In the following example, InputCursor is used to identify x,y coordinates of an input point feature class. These point coordinates are used to calculate the corner locations for square buffer polygons that are entered into the output using InsertCursor.
Using only geoprocessing tools, a square buffer can also be calculated using the Buffer and FeatureEnvelopeToPolygon tools in succession.
import os
# Input point feature class
inPoints = gp.GetParameterAsText(0)
# Output polygon feature class
outPolys = gp.GetParameterAsText(1)
#Buffer distance
bufDist = gp.GetParameterAsText(2)
# Boolean type: Maintain fields and field values of the input in the output
keepFields = gp.GetParameterAsText(3)
# Prepare the output based on whether field and field values are desired in the output
if keepFields:
# Create empty output polygon feature class that includes fields of the input
gp.CreateFeatureClass(os.path.dirname(outPolys), os.path.basename(outPolys), "POLYGON", inPoints, "", "", inPoints)
# Create a short list of fields to ignore when moving fields values from input to output
ignoreFields = []
# Use Describe properties to identify the ShapeFieldName and OIDFieldName
desc = gp.Describe(inPoints)
ignoreFields.append(desc.ShapeFieldName)
ignoreFields.append(desc.OIDFieldName)
# Create a list of fields to use when moving field values from input to output
fields = gp.ListFields(inPoints)
fieldList = []
for field in fields:
if field.Name not in ignoreFields:
fieldList.append(field.Name)
else:
# Create empty output polygon feature class without fields of the input
gp.CreateFeatureClass(os.path.dirname(outPolys), os.path.basename(outPolys), "POLYGON", "", "", "", inPoints)
# Open searchcursor
inRows = gp.SearchCursor(inPoints)
inRow = inRows.Next()
# Open insertcursor
outRows = gp.InsertCursor(outPolys)
# Create point and array objects
pntObj = gp.CreateObject("Point")
arrayObj = gp.CreateObject("Array")
while inRow: # One output feature for each input point feature
inShape = inRow.Shape
pnt = inShape.GetPart(0)
# Need 5 vertices for square buffer: upper right, upper left, lower left,
# lower right, upper right. Add and subtract distance from coordinates of
# input point as appropriate.
for vertex in [0,1,2,3,4]:
pntObj.id = vertex
if vertex in [0,3,4]:
pntObj.x = pnt.x + bufDist
else:
pntObj.x = pnt.x - bufDist
if vertex in [0,1,5]:
pntObj.y = pnt.y + bufDist
else:
pntObj.y = pnt.y - bufDist
arrayObj.add(pntObj)
# Create new row for output feature
feat = outRows.NewRow()
# Shift attributes from input to output
if keepFields:
for fieldName in fieldList:
feat.SetValue(fieldName, inRow.GetValue(fieldName))
# Assign array of points to output feature
feat.Shape = arrayObj
outRows.InsertRow(feat)
# Clear array of points
arrayObj.RemoveAll()
# Get next feature in searchcursor
# Delete inputcursor
del outRows
