Error reporting for ArcGIS software crash data |
Release 9.3
Last modified September 2, 2008 |
Print all topics in : "World" |
ArcGIS Desktop 9.3 applications are capable of capturing software crash data. This crash data can be sent as an error report to the ESRI development team to analyze and fix the errors. Sending reports about software crashes to ESRI is very helpful for a number of reasons.
The error report that we receive from you includes important and detailed information that often enables us to repair a problem that we have no other means of tracking down. Many of these errors cannot be easily reproduced. These types of errors occur in many situations -- for example, when the software is used for very long periods of time and a memory leak has occurred which consumes the available system resources, when a hardware limitation is reached, when ArcGIS is used with some third party software extensions that have not yet been updated to work with your version of ArcGIS.
The contents of the error report that you send to us will give the ESRI development team insight into how to better engineer the software to avoid these errors in the future.
Whenever you encounter errors that occur with repeatable steps, you should always contact ESRI's Technical Support. When providing the steps to reproduce the problem that creates an error report, you should also include the error report.
The most recent 10 error reports that have occurred on your system are saved to the application data location on your local hard drive:
C:\Documents and Settings\<User Name>\Application Data\ESRI\ErrorReports
NOTE: All Error Reports are treated as confidential to ESRI and their usage is covered by the ESRI Privacy Policy.
When a software crash occurs in ArcGIS, you will be presented with the option to send an error report to ESRI, or not. If you choose "send", this error report is sent directly to the ESRI development team.
When you send an error report, you can optionally provide an email address for this issue. If the ESRI development team needs more information, they may contact you.
NOTE: This address may vary for different organizations. A Web page will display the proper email address to which you should send the saved error report.
ArcGIS Administrators can configure how the error reports operate for their organization by customizing the local machine registry.
%APPDATA%\ESRI\ErrorReports\
HKCU\Software\ESRI\Settings\ErrorReports
Setting | Type | Description |
EnableErrorReport | DWORD | If set to 0, error reporting is disabled. You will see a dialog letting you know that a error has occurred. |
ShowErrorDialog | DWORD | If set to 0 no dialog will be shown. |
EmailAddress | String | The email address that appears in the dialog (default ArcGISErrorReport@esri.com). |
YourEmailAddress | String | The email address that will be sent to the web service. |
EnableWebService | DWORD | If set to 1 send the error reports to the web service. |
CacheSize | DWORD | The number of error reports to save on you disk.
EnableErrorReport | ShowErrorDialog | EnableWebService | Action |
1 | 1 | 1 | Dialog asking if you want to send the error report to ESRI. The error report is saved to your local disk. |
1 | 1 | 0 | Dialog asking if you want to save the error report and email it to ESRI. The error report is saved to your local disk. |
1 | 0 | 0 | No dialog is shown. The error report is saved to you local disk. |
1 | 0 | 1 | No dialog is shown and the error report is automatically sent to ESRI. The error report is saved to you local disk. |
0 | Any | Any | Dialog telling you a serious error has occurred. The error report is saved to you local disk |
At ESRI, we want to work hard to address your software issues and to make repairs whenever we can. We look at all of the issues reported by users.
ESRI uses an automated system to log all error reports sent by users and to perform an initial analysis of the problem. We also track how many times each issue has been reported. Each issue is assigned to a specific development team who evaluate each issue and determine a course of action.
We identify all issues that we can fix and address them through bug repairs which are tested, validated, and installed for delivery in a service pack or the next major software release.
