Show Navigation | Hide Navigation
Draw toolbar
Release 9.3
Last modified April 24, 2009
E-mail This Topic Printable Version Give Us Feedback
The image below shows the Draw toolbar which typically appears along the bottom of the ArcMap application window. The Draw toolbar is used to add and edit graphical elements on your map layout page.
Note: Refer to the Editor toolbar to see how to edit geodatabase features within the active data frame.
Draw toolbar
Draw toolbar buttons and their functions
Button Name Function
Select Elements
Select Elements Allows you to select, resize, and move text, graphics, and other objects placed on the map
Rotate
Rotate
Rotates the selected text or graphics
Zoom to Selected Elements
Zoom To Selected Elements Zooms the map display to the selected elements
New Rectangle
New Rectangle Draws a rectangle
New Polygon
New Polygon Draws a polygon
New Circle
New Circle Draws a circle
New Ellipse
New Ellipse Draws an ellipse
New Line
New Line Draws a line
New Curve
New Curve Draws a curve
New Freehand
New Freehand Draws a freehand line
New Marker
New Marker Draws a marker point
New Text New Text Allows you to add text to the map by typing it in
New Splined Text
New Splined Text Allows you to add curved text to the map by typing it in
Label
Label Labels the feature you click with the value for the layer's label field
Callout
Callout Adds a text callout
New Polygon Text
New Polygon Text Creates new paragraph text that flows within a polygon graphic shape
New Rectangle Text
New Rectangle Text Creates new paragraph text that flows within a rectangle graphic shape
New Circle Text
New Circle Text Creates new paragraph text that flows within a circle graphic shape
Edit Vertices
Edit Vertices Allows you to edit the vertices of the selected line, polygon, or curve
Bold
Bold Toggles bold font on and off
Italic
Italic Toggles italic font on and off
Underline
Underline Toggles underline font on and off
Font Color
Font Color Allows you to change the font color
Fill Color
Fill Color Allows you to change the fill color
Line Color
Line Color Allows you to change the line color
Marker Color
Marker Color Allows you to change the marker color
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
