Show Navigation | Hide Navigation
You are here:
Geoprocessing > Automating your work with scripts > Scripting object: Properties and Methods > Properties and Methods
ListIndexes method
Release 9.3
Last modified January 19, 2010
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Properties and Methods"
Related Topics
Note: This topic was updated for 9.3.1.
Lists all the indexes in the specified table, feature class, or shapefile. Specifying search conditions (wildcard) limits the results. This method and ListFields are the only two List methods that don't require you to preset the workspace.
Returns a Python List that will contain index objects.
NOTE: The content below describes the use of ListIndexes using a 9.3-version geoprocessor. When using a 9.2-version geoprocessor, ListIndexes returns an enumeration instead of a Python List. For more information, see Differences between geoprocessor versions.
Syntax
object.ListIndexes(InputValue As String, {wildCard} As String) As Python List
{} = optional
Part Description
object The instantiated geoprocessing object.
InputValue The name, path, or both of the table, feature class, or shapefile whose indexes are to be listed.
wildCard Optional. Combination of * and characters that helps to limit the results. The asterisk is the same as saying ALL. If no wildcard is specified, all indexes in the workspace will be returned.
Index object properties
Name—Returns the name
IsAscending—Returns True if the index is sorted in ascending order
IsUnique—Returns True if the field is unique
Fields—Returns a Python List of field objects for this table
Examples
import arcgisscripting
gp = arcgisscripting.create(9.3)
fc = "c:/county/roads.shp"
indexes = gp.listindexes(fc)
while index:
    print "Name: " + index.Name
    print "IsAscending: " + index.IsAscending
    print "IsUnique: " + index.IsUnique
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
