Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Conversion toolbox > To Geodatabase toolset > Tools
Feature Class To Feature Class (Conversion)
Release 9.3
Last modified November 21, 2008
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Tools"
Related Topics
Converts a shapefile, coverage feature class, or geodatabase feature class to a shapefile or geodatabase feature class.
Usage tips
Command line syntax
An overview of the Command Line window
FeatureclassToFeatureclass_conversion <in_Features> <out_path> <out_name> {where_clause} {field_mapping} {config_keyword}
Parameter Explanation Data Type
<in_Features>
The feature class or feature layer that will be converted.
Feature Layer
<out_path>
The location in which the output feature class will be created. This can be either a geodatabase or a folder. If the output location is a folder, the output will be a shapefile.
Workspace | Feature Dataset
<out_name>
The name of the output feature class.
String
{where_clause}
A SQL expression used to select a subset of features.
The syntax for the expression differs slightly depending on the data source. For example, if you're querying file or ArcSDE geodatabases, shapefiles, or coverages, enclose field names in double quotes:
"MY_FIELD"
If you're querying personal geodatabases, enclose fields in square brackets:
[MY_FIELD]
For more information on SQL syntax and how it differs between data sources, see SQL reference.
SQL Expression
{field_mapping}
The fields and field contents chosen from the inputs. Each of the unique input fields will be listed on the Field Map window, and when expanded, you will see a list of all the input field occurrences (subfields). New fields can also be added.
For each Field Map, you can add, rename, or delete output fields as well as set properties such as data type and merge rule. You can also delete an output field's subfields, and you can format any output field's values if the data type is text.
Learn more about choosing and setting the output fields.
Field Mappings
{config_keyword}
Specifies the storage parameters (configuration) for geodatabases in file and ArcSDE geodatabases. Personal geodatabases do not use configuration keywords.
ArcSDE configuration keywords for ArcSDE Enterprise Edition are set up by your database administrator.
String
Data types for geoprocessing tool parameters
Command line example
FeatureclassToFeatureclass d:\geodatab\shapefiles\census\blockgrp.shp c:\geodata\portland.mdb fip410510033013 ("FIPS" = 410510033013)
FeatureclassToFeatureclass d:\geodatab\shapefiles\census\blockgrp.shp c:\geodata\portland.mdb block ("BLOCKNAME" = 'downtown')
Scripting syntax
About getting started with writing geoprocessing scripts
FeatureclassToFeatureclass_conversion (in_Features, out_path, out_name, where_clause, field_mapping, config_keyword)
in_Features (Required)
Feature Layer
out_path (Required)
out_name (Required)
String
where_clause (Optional)
"MY_FIELD"
[MY_FIELD]
SQL Expression
field_mapping (Optional)
Field Mappings
config_keyword (Optional)
String
Script example
# FeatureClassToFeatureClassExample.py
# Description: Converts a shapefile to a geodatabase
# Requirement: None
# Author: ESRI
# Date: 12/12/03
# Create the Geoprocessor object
import arcgisscripting
gp = arcgisscripting.create()
# Set some local variables
inFC= "C:/data/roads.shp"
outLocation = "C:/data/myPGDB.mdb"
outFCName = "NF_Roads"
expression = " \"ROADS_CODE\" = \'one\' "
# Use error trapping in case an error occurs during conversion
try:
    # Process: FeatureClass To FeatureClass...
    gp.FeatureClassToFeatureClass_conversion(inFC, outLocation, outFCName, expression)
except:
    print "An error occurred"
    print gp.GetMessages()
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
