Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Data Management toolbox > Generalization toolset > Tools
Aggregate Polygons (Data Management) (ArcInfo only)
Release 9.3
Last modified March 8, 2012
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Tools"
Related Topics
NOTE: This topic was updated for 9.3.1.
Combines polygons within a specified distance to each other into new polygons
Illustration
Aggregate Polygons illustration
Usage tips
Command line syntax
An overview of the Command Line window
AggregatePolygons_management <in_features> <out_feature_class> <aggregation_distance> {minimum_area} {minimum_hole_size} {NON_ORTHOGONAL | ORTHOGONAL}
Parameter Explanation Data Type
<in_features>
The polygon features to be aggregated.
Feature Layer
<out_feature_class>
The output feature class to be created.
Feature Class
The distance to be satisfied between polygon boundaries for aggregation to happen. A distance must be specified, and it must be greater than zero. You can specify a preferred unit; the default is the feature unit.
Linear Unit
{minimum_area}
The minimum area for an aggregated polygon to be retained. The default value is zero, that is, to keep all polygons. You can specify a preferred unit; the default is the feature unit.
Areal Unit
{minimum_hole_size}
The minimum size of a polygon hole to be retained. The default value is zero, that is, to keep all polygon holes. You can specify a preferred unit; the default is the feature unit.
Areal Unit
Specifies the characteristic of the input features that will be preserved when constructing the aggregated boundaries.
  • NON_ORTHOGONAL — Specifies natural features, such as vegetation or soil polygons, for which the non_orthogonal shapes will be preserved and constructed. This is the default.
  • ORTHOGONAL — Specifies building-like features for which orthogonal shapes will be preserved and constructed.
Boolean
Data types for geoprocessing tool parameters
Command line example
aggregatepolygons_management c:\mapData.mdb\buildings h:\mapDataNew.mdb\residential_areas 5 25 orthogonal
Scripting syntax
About getting started with writing geoprocessing scripts
AggregatePolygons_management (in_features, out_feature_class, aggregation_distance, minimum_area, minimum_hole_size, orthogonality_option)
in_features (Required)
Feature Layer
out_feature_class (Required)
Feature Class
aggregation_distance (Required)
Linear Unit
minimum_area (Optional)
Areal Unit
minimum_hole_size (Optional)
Areal Unit
orthogonality_option (Optional)
Boolean
Script example
import arcgisscripting
gp = arcgisscripting.create()
gp.workspace = "h:\\workspace"
gp.toolbox = "management"
gp.aggregatepolygons("trees", "vegetation", 10, 150)
# AggregatePolygonsWithAttributeTransfer.py
# Description: Example of aggregating residential houses into builtup areas
# and then deriving the total population for the builtup areas.
# Author: ESRI
# Date: 04/23/08
# Create the Geoprocessor object
import arcgisscripting, sys, string, os
myWorkspace = "c:/data/urban_features.gdb"
myFeatures = "Houses"
try:
    # Set the workspace (to avoid having to type in the full path to the data every time)
    gp.Workspace = MyWorkspace
    # Given the input feature class named "Houses" with a field "COUNT" for family member count.
    # Process: Aggregate Polygons  to create Builtup_areas polygons
    # and the one-to-many relationship table Builtup_areas_Tbl
    gp.AggregatePolygons_management(myFeatures, "Builtup_areas", "100 Meters", "0 Unknown", "0 Unknown", "ORTHOGONAL")
    # Process: Join Field to join Buildup_areas_Tbl using INPUT_FID as join field
    #  with input Houses using the OBJECTID as join field, and specify COUNT as the field to transfer.
    #  This will transfer the COUNT field and its values into Builtup_areas_Tbl.
    gp.JoinField_management("Builtup_areas_Tbl", "INPUT_FID", myFeatures, "OBJECTID", "Count")
    # Process: Frequency on the Builtup_areas_Tbl using the OUTPUT_FID as the frequency field
    # and specify to summarize the COUNT values (total population). The output table Builtup_areas_Tbl_Frequency
    # will now contain the total population for each OUTPUT_FID.
    gp.Frequency_analysis("Builtup_areas_Tbl", "Builtup_areas_Tbl_Frequency", "OUTPUT_FID", "Count")
    # Process: Join Field again to join Builtup_areas using OBJECTID as join field
    # with Builtup_areas_Tbl_Frequency table using the OUTPUT_FID as join field, and
    # specify COUNT as the field to transfer. This will transfer the COUNT field and its values into
    # Builtup_areas (the aggregated polygons).
    gp.JoinField_management("Builtup_areas", "OBJECTID", "Builtup_areas_Tbl_Frequency", "OUTPUT_FID", "Count")
except:
    # If an error occurred while running a tool, print the messages
    print gp.GetMessages()
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
