Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Geostatistical Analyst toolbox > Tools
GA Layer to Grid (Geostatistical Analyst)
Release 9.3
Last modified November 10, 2008
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Tools"
Exports a Geostatistical layer to an ArcInfo GRID
Usage tips
Command line syntax
An overview of the Command Line window
GALayerToGrid_ga <in_geostat_layer> <out_surface_grid> {cell_size} {points_per_block_horz} {points_per_block_vert}
Parameter Explanation Data Type
<in_geostat_layer>
Input geostatistical layer
Geostatistical Layer
<out_surface_grid>
The ArcInfo GRID to be created
Raster Dataset
{cell_size}
The cell size at which the output GRID will be created
Analysis cell size
The number of predictions for each cell in the horizontal direction for block interpolation
Long
The number of predictions for each cell in the vertical direction for block interpolation
Long
Data types for geoprocessing tool parameters
Command line example
GALayerToGrid c:/data/idw.lyr c:/data/out_grid 2 1 1
Scripting syntax
About getting started with writing geoprocessing scripts
GALayerToGrid_ga (in_geostat_layer, out_surface_grid, cell_size, points_per_block_horz, points_per_block_vert)
in_geostat_layer (Required)
out_surface_grid (Required)
Raster Dataset
cell_size (Optional)
Analysis cell size
points_per_block_horz (Optional)
Long
points_per_block_vert (Optional)
Long
Script example
# Purpose: Export a Geostatistical layer to a GRID.
# Create the Geoprocessor object.
import arcgisscripting
gp = arcgisscripting.create()
try:
    # Set the input GA layer.
    inputGALayer = "c:/data/Input/idw.lyr"
    # Set the output grid name.
    outputGrid = "out_grid"
    # Set some of the parameters.
    cell_size = 2
    points_horiz = 1
    points_vert = 1
    # Check out GeoStatistical Analyst extension license.
    gp.CheckOutExtension("GeoStats")
    # Process: GA Layer To Grid...
    gp.GALayerToGrid_ga (inputGALayer, outputGrid, cell_size, points_horiz, points_vert)
except:
    # If an error occurred while running a tool, then print the messages.
    print gp.GetMessages()
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
