You are here:
Mapping and visualization
Navigating and interacting with maps
Interacting with maps
About identifying features
This topic was updated for 9.3.1.
When you want information about a feature displayed in ArcMap, you can use the Identify tool
on the Tools toolbar. The Identify tool allows you to see the of your data and is an easy way to learn something about a location in a map. Clicking the Identify tool on a location inside a data frame will present the attributes of the data at that location. When identifying features with the Identify tool, the attributes are presented in a feature-by-feature, layer-by-layer manner in the Identify window.
The Identify tool can be customized to narrow down the amount of data you see by either filtering the layers you are interested in or by customizing the field properties of those layers. By reducing the number of layers the Identify tool works with, you can quickly focus on what is important to you when exploring a map. By customizing which fields are shown and setting , you can ensure that the Identify tool returns only the most appropriate fields, using field names that are easy to understand. In particular, the Primary Display Field, which is a layer property on the Fields tab of the Layer Properties dialog box, is used to determine the text in the left panel of the Identify window. It's a good practice to test the results of your formatting with the Identify tool before sharing a map document or publishing a map.
Accessing the Identify tool
The Identify tool can be accessed in a number of ways. The most popular is to click it on the Tools toolbar but you can also access it by right-clicking
- The map in data view
- A result listed in the Find dialog box
- A record in the table window
When you click the Identify tool on the Tools toolbar in ArcMap, the Identify window immediately appears, enabling you to choose which layers you want to identify before you click the map to identify a feature. This makes the Identify tool more convenient if you don't want to use the default topmost layer setting. It also enables you to position the window conveniently on the screen so it doesn't cover up the map area you're viewing. In ArcCatalog, the Identify tool doesn't open the Identify window when it's selected because you normally only work with one layer at a time in the ArcCatalog Preview window.
Choosing which layers to identify
When you use the Identify tool, it defaults to identifying the topmost layer in your map. If you click a location and do not find that the topmost layer interests you, you can use the Layers drop-down list at the top of the Identify window to choose from specific layers in your map or generic layer settings.
The Identify tool will act on whichever option you choose in the Layers drop-down list:
Topmost layer: Identify will give you the attributes of the feature or features from the layer that is uppermost in the drawing hierarchy—in other words, highest in the table of contents Display tab—at the location you click. This option won't identify features in a layer that is turned off in the table of contents or currently not being drawn because of the scale of the map. With this setting, you'll usually get the attributes of the feature you click without getting the attributes of features in other layers that are drawn underneath that feature.
- Visible layers: Identify will give you the attributes of the features belonging to all layers that are currently drawn on the map at the location you click.
- Selectable layers: Identify will give you the attributes of the features belonging to layers at the location you click that are checked on the table of contents Selection tab or the Set Selectable Layers dialog box. If a layer is selectable, its features will be identifiable even if the layer is not currently drawn on the map. The Selectable layers option can be useful as your default because it restricts Identify to the same set of layers on which interactive selection operates.
- All layers: Identify will give you the attributes of the features from all the layers at the location you click. This includes layers that are not currently drawn on the map. This setting is useful if you want to get a cross section of all the attributes of all layers at a particular location.
In addition, you can choose a specific layer in your map to identify. If you choose a particular layer name rather than a generic option, its features will be identifiable even if the layer is not currently drawn on the map.
Why does Identify let you identify a feature that's not drawn on the map? This is because in some situations you may want to be able to access a layer's attributes without drawing its features. For example, you may want to be able to find out what ZIP Code a particular street segment is located in without drawing the ZIP Code boundaries on your street map. In this case, you would choose the ZIP Code layer from this drop-down list but turn this layer off in the table of contents. Clicking a street with the Identify tool will give you the attributes of the ZIP Code layer at the location you clicked.
Working in the Identify window
The results of an identify operation displays in the window and shows three categories of information: a list of features that have been identified, the attributes belonging to each identified feature, and location coordinates.
The left side of the window lists each feature that has been identified. Features are listed using the value of the layer's Primary Display Field, under the name of the layer to which they belong. You'll see multiple layers listed if you have identified features from more than one layer.
The right side of the window shows the attributes of the feature you identified. When you have identified features, you can click a particular feature in the list on the left and see its attributes in the right panel. In this way, you can compare attributes for different features. You can interact with the attributes of identified features by right-clicking within the attributes panel.
The x,y coordinates for the location you clicked are displayed on the right side of the window above the attributes panel. When you click an identified feature from the list on the left, the location box will display the x,y coordinates of that feature's location (if it is a point feature) or centroid (if it is any other type of feature). You can also choose the units with which these coordinates are displayed and you can select the coordinates and copy them.
Working with Identify results
You can interact with identified features by right-clicking a feature in the list on the left side of the window. This menu allows you to do a number of actions with the identified feature including selecting, flashing, zooming, and panning to it. You can also manage and access hyperlinks set for the feature, create spatial bookmarks based on the extent of the identified feature, organize the list of identified features, and copy the feature's attributes.
The Identify window is one way of viewing related information about the feature you identified. Related information is data that has been expressly associated with the geographic feature you clicked by either a geodatabase relationship class or by a relate in ArcMap. For example, if you have a table of landowners that is related to a parcel feature class, you can identify a parcel feature, then view the related attributes in the owner table. You can use the expansion controls to navigate any related information.
If you want to display related data using the field properties (primary display field, field aliases, field visibility and number formatting) of the table or layer that represent that related data in your map, right-click any entry in the tree on the left-hand side of the Identify window and click Show Relates With Field Properties. If you access related data while this option is checked and the related data is not in your map, the fields are listed in the usual way because there are no field properties available for Identify to use. If multiple layers represent the related data, you can choose which one to use to view the related data. The setting is stored in the registry for the application.
Learn more about working with spatial bookmarks
Learn more about adding hyperlinks to features
Working with the attributes of identified features
By clicking or right-clicking the right side of the Identify window, you can interact with the attributes of identified features. Some of the tasks you can perform include accessing hyperlinks and rasters, managing fields, and copying field names or attribute values. When you have hyperlinks or rasters available, you'll see their icons in the Value column.
- Accessing hyperlinks: A field that contains a text value that is a full URL or full path can be used to link to either a Web site () or launch a document. This enables you to link from fields in the Identify window without defining a hyperlink field in the layer's properties.
These hyperlinks do not support the hyperlink base property on the Document Properties dialog box; they must be complete URLs or paths. URLs must start with either http:// or https://, and paths must start with a disk drive or be a full UNC path. Windows environment variables are recognized as hyperlinks as long as they are defined at the system or current user level. You can have as many fields as you want that contain URLs or paths to documents, and values for a field can include both URLs and paths. The logic for recognizing the values as clickable links is built into the Identify window, and you don't need to set any layer or document properties.
- Viewing images in a field of type raster: The attribute tables of geodatabase feature classes and stand-alone tables in geodatabases can contain a field of type raster. These fields can contain any supported image or raster file such as a photo of a feature. When you identify a feature containing a raster field, a small icon appears next to the raster field if a picture exists for the record. Clicking it opens the raster in a new window.
Learn more about fields of type raster
- Managing fields: You can hide, show, sort, and select fields by right-clicking the right side of the Identify window. You can also sort the attribute list by clicking either the Field or Value title bar above the results.
- Copying fields and values: To copy all the field names and attribute values, right-click the left side of the window and use the Copy Record command. You may want to hide the fields you don't want to copy. To copy individual field names or individual values, right-click the right side and click Copy. For a field/value pair, right-click the right side and click Copy Selected Fields.
How to identify features
Identifying features
- Click the Identify tool
The Identify window opens.
- Click the map feature you want to identify.
The features in the topmost layer (by default) under the pointer will be identified.
- Right-click the left side of the window to interact with the identified features, or the right side to work with their attributes.
- Hold down the Shift key while clicking the map to keep the results of your previous clicks in the Identify window.
- You can drag a box with the Identify tool to identify all the features inside the box.
- Feature geometry is needed to use the Flash, Zoom To, Pan To, and Create Bookmark commands. In some cases, feature geometry is not available, so these commands are disabled. These cases include the identification of features from any WMS layer and features from an ArcIMS image service that does not include geometry in any query results.
- Click a feature to flash it on the map. Clicking a layer will flash all identified features for that layer.
- Click a field to select it. When a field is selected, it will remain visible in the right side of the window as you identify additional features from that layer or switch between features from that layer in the left side of the window. This makes it easy to compare the attributes for multiple features, especially when the layer has a large number of fields.
- Fields that you have hidden from the attribute table window for the layer are also hidden in the Identify window. If you want to hide additional fields in just the Identify window, right-click and click Hide Field(s). Use Show All Fields to show fields that you have hidden. Hiding fields in the Identify window is temporary and only affects your current Identify session. It does not affect which fields are shown or not shown in any other dialog boxes or the attribute table.
- Hold down Ctrl and click any + or - control to expand or contract all the entries in the identified results tree at the same level as the one you clicked. This makes it faster to work with the tree.
- When you right-click a feature in the left side of the window, the menu has several commands that make it easy to work with features you have identified. For example, you can sort the features and remove unwanted ones from the window. Copy Record copies all the attributes of the feature you right-clicked.
- To change the primary display field for a layer, double-click the layer in the table of contents and click the Fields tab on the Layer Properties dialog box. The new field you specify will be used the next time you identify a feature from that layer.
- The <Selectable layers> option in the Identify window can be useful as your default because it restricts Identify to the same set of layers on which interactive selection operates. In this way, you can use the Selection tab in the table of contents or the Selection > Set Selectable Layers dialog box to specify exactly which layers you want to identify.
- If you want to display related data using the field properties (primary display field, field aliases, field visibility, and number formatting) of the table or layer that represent that related data in your map, right-click any entry in the tree on the left side of the Identify window and click Show Relates With Field Properties. If you access related data while this option is on and the related data is not in your map, the fields are listed in the usual way because there are no field properties available for Identify to use. If multiple layers represent the related data, you can choose which one to use to view the related data. This setting is stored in the registry, so it will be the default behavior every time you use the Identify tool. Simply uncheck the context menu entry to turn it off again.
Changing the search tolerance of the Identify tool
- Click Selection on the main menu and click Options.
- Type a new selection tolerance. The default is 3 pixels.
- Click OK.
- If you get the attributes of several features from the same layer, it means there are several features in that layer within the selection tolerance at the location you clicked. If you still get several features after making the tolerance smaller, it probably indicates that there are overlapping features in the layer at that location such as a number of point features at the same location.
- The selection tolerance is also used by other tools including the Select Features, Edit, and Hyperlink tools. This setting is stored in your map document.
Changing the default layer of the Identify tool
- Click Tools on the main menu and click Options.
- Click the General tab.
- Click the Default Layer Option drop-down arrow and click the layer type you want to use.
- Click OK.
- ArcMap defaults to identifying from the topmost layer. You can change the default setting, which applies to ArcMap, ArcScene, and ArcGlobe (if you have the ArcGIS 3D Analyst extension), on the General tab of the Tools > Options dialog box. The default you choose won't always be reflected in the window launched by the Identify tool if you have already used this tool in your current session. This is because once you use the Identify tool in a session, the tool remembers which option you used for the duration of the session and doesn't normally revert to its default.
Changing the units of the x,y coordinates displayed
- On the right side of the Identify window, click the small arrow next to the location information.
- Click the units you want to use.
- If you want to type in an x,y coordinate and pan or zoom to that location or draw a point on the map there, use the Go To XY button
