Show Navigation | Hide Navigation
You are here:
Mapping and visualization > Navigating and interacting with maps > Interacting with maps
Measuring distances and areas
Release 9.3
Last modified April 24, 2009
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Interacting with maps"
Related Topics
About measuring distances and areas
Note: This topic was updated for 9.3.1.
The Measure tool lets you draw on the map to measure lines and areas. You can use this tool in several ways. For example, you can draw a line or polygon on the map and get its length or area, or you can even click directly on a feature and get measurement information.
When you click the Measure tool, the Measure window appears. This dialog box allows you to set different options for how you measure including whether to measure lines, areas, or features; use snapping; and set which units are reported. Measurements are displayed inside the window, so it is easy to copy and paste them into other applications.
Measure dialog box with results
The Measure window contains tools for measuring distance and features. By default, the distance (line) measurement tool is enabled until you choose a different option from the Measure window.
The tools on the Measure window are listed below:
Geodesic versus Cartesian measurements with the Measure tool
By default, if the data frame is using a projected coordinate system, 2D Cartesian mathematics is used to calculate distances. The measurement reflects the projection of the 3D data onto the 2D surface and does not take into account the curvature of the earth. You can hold down the Shift key while measuring to get the geodesic distance instead. This is calculated using the spheroid/ellipsoid of the data frame's projected coordinate system's geographic coordinate system.
If the data frame is using a geographic coordinate system and the display units are linear, the measurements are geodesic by default and you don't need to hold down Shift.
How to measure distances and areas
Measuring distance and areas
  1. Click the Measure tool Measure button on the Tools toolbar.
  2. Click the Measure A Line button Measure Line or the Measure An Area button Measure An Area.
  3. Click the map at the location where you want to start measuring.
  4. Move the pointer to the next point that you want to measure and click. If you would like to measure along the curve of a line, click along the line to add vertices.
  5. Double-click when you want to end the line or polygon.
  6. The results are displayed in the Measure window.
Tips
  • To measure areas, your data frame must be using a projected coordinate system. The Measure An Area button will be disabled if the coordinate system is unknown or geographic.
  • When you use the Measure tool in snapping mode, it will snap to the vertices of lines and polygons, or to point features, by default. This makes it easy to trace over features such as to measure the distance between street intersections. If you want to snap to edges (the parts of lines where there is no vertex such as the edge of a parcel with straight sides), hold down Ctrl when measuring.
  • If the data frame is using a projected coordinate system, 2D Cartesian mathematics is used to calculate distances. You can hold down the Shift key while measuring to get the geodesic distance instead. However, if the data frame is using a geographic coordinate system, the measurements will always be geodesic and you don't need to hold down Shift.
  • The Measure tool's snapping option uses 8 pixels of the display as the snapping tolerance. It doesn't use the editing snapping environment.
Measuring feature lengths and areas
  2. Click the Measure A Feature button Measure A Feature on the Measure dialog box.
  3. Click a feature on the map.
  4. The results are displayed in the Measure window.
Tips
  • The Calculate Geometry command, which is accessed from the table window, will calculate lengths, areas, x,y coordinates, and so on, and place the values into a field in the attribute table. To learn more about Calculate Geometry, see Making field calculations.
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
