Show Navigation | Hide Navigation
You are here:
Geodatabases and ArcSDE > Administering File and Personal geodatabases
Upgrading file and personal geodatabases
Release 9.3
Last modified November 25, 2008
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Administering File and Personal geodatabases"
About upgrading file and personal geodatabases
Geodatabases built with previous versions of ArcGIS do not support some of the newer functions of ArcGIS. If your geodatabase was developed using a previous version of ArcGIS, you may want to upgrade it. Upgrading a file or personal geodatabase is optional in most cases, but if you do not upgrade, you will not have access to newer functionality.
Once a geodatabase has been upgraded, most older versions of ArcGIS will be unable to open it since older versions of ArcGIS cannot read newer versions of the geodatabase.
There are two exceptions to this rule:
You may want to make a copy of the geodatabase and upgrade the copy so you have both an original and an upgraded version. This is not unique to file and personal geodatabases; you should also make a backup copy of ArcSDE geodatabases before upgrading them as well.
How to upgrade file and personal geodatabases
  1. Start ArcCatalog.
  2. Right-click the geodatabase you want to upgrade and click Properties.
  3. Click the General tab.
  4. Click the Upgrade button at the bottom of the dialog box.
  5. Click OK.
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
