You are here:
Data support in ArcGIS
Terrains
Managing terrain datasets
The following are some things to keep in mind when modifying a :
- When appending measurements to an existing terrain dataset, they should be adjacent to measurements already in the terrain. The dataset should grow as a unified area rather than in fragmented pieces.
- Edits to measurements can have an impact on the terrain surface that spans tile boundaries. Therefore, when one tile is made dirty, the build process will include the tile and its immediate neighbors, for a total of nine. When you make edits in contiguous tiles, you have a more efficient build process than when editing disparate tiles. Consider this in the editing workflow.
- Copy the entire feature dataset when moving a terrain dataset to another location.
- When obtaining data to add to a terrain dataset, the data should be in the same projected coordinate system as the terrain dataset. Unknown coordinate systems are not recommended. Geographic coordinates, such as decimal degrees, are not supported.
- Don't build a terrain dataset in an edit session.
- Don't perform schema editing in an edit session.
Please visit the
Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
