Show Navigation | Hide Navigation
You are here:
Extensions > PLTS > Editing data in PLTS > Editing existing features
Converting points to lines or polygons
Release 9.3
Last modified February 4, 2009
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Editing existing features"
Related Topics
About converting points to lines or polygons
The PLTS Points to Line or Polygon tool allows you to generate a linear or polygon feature from a selected set of points depending on the selected target layer.
For example, you can load a set of collected points from a Global Positioning System (GPS) unit into ArcGIS and use this tool to create polyline or polygon features from those points. Ideally, the points would be loaded with associated waypoint IDs that can be used to determine to which path or area the points belong and/or define draw order.
With the PLTS Points to Line or Polygon tool, you can define how the polyline or polygon feature you want to create is drawn from the selected points. The Select draw order drop-down arrow on the Pts to Ln/Poly dialog box displays a set of options associated with numeric values. The PLTS Points to Line or Polygon tool uses the numeric values of the option you select, going from lowest to highest, to create the polyline or polygon feature.
Choosing the Sort Field option for either line or polygon target layers displays another list of options in the Select sort field drop-down list that changes dynamically depending on the selected feature layer. This list is populated with all the layer's numeric fields. The PLTS Points to Line or Polygon tool uses these selected numeric values to create the polyline or polygon feature, drawing from lowest to highest.
For polygon feature layers, the Convex Hull option provides another method to define how the polygon is created. Convex Hull represents the shape of the selected points, regardless of draw order and without internal holes.
How to convert points to lines or polygons
Adding the PLTS Points to Line or Polygon tool
  1. In ArcMap, click the Tools menu and click Customize.
  2. The Customize dialog box appears.
  3. Click the Commands tab.
  4. In the Categories list, choose PLTS Editing.
  5. In the Commands list, click and drag the PLTS Points to Line or Polygon tool PLTS Points to Line or Polygon to a toolbar.
  6. Click Close.
  1. If necessary, verify that a polyline or polygon layer is selected as the target layer.
  2. Start an edit session.
  3. Click the PLTS Select Tool Select Features and select at least two points from the same feature class.
  4. Click the PLTS Points to Line or Polygon button PLTS Points to Line or Polygon.
  5. The Pts to Ln/Poly dialog box appears.
  6. Click the Select draw order drop-down arrow and choose a draw order option.
  7. Pts to Ln/Poly draw order list
    Choosing the Sort Field option causes the Select sort field drop-down list to become available.
    Pts to Ln/Poly dialog box with Sort Field option
  8. Click the Select sort field drop-down arrow and choose an appropriate sort field.
  9. Pts to Ln/Poly dialog box Select sort field
  10. Click Create.
  11. The Pts to Ln/Poly dialog box closes, and the linear or polygon feature is created and written to the selected target layer.
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
