Using Crystal Reports |
Release 9.3
Last modified April 24, 2009 |
![]() ![]() ![]() Print all topics in : "Creating reports" |
This topic was updated for 9.3.1.
NOTE: Starting at 9.3, the full Crystal Reports™ product from Business Objects, which provides an advanced report authoring application, is no longer included with ArcGIS Desktop.
ArcGIS Desktop 9.1 and 9.2 included Crystal Reports XI Release 1. If you are upgrading to ArcGIS Desktop 9.3 from 9.1 or 9.2, you can continue to use your Crystal Reports XI software with 9.3. In order to enable the Tools > Reports > Crystal Reports Wizard in ArcMap 9.3, you need to install the Crystal Reports XI Release 2 runtime. This install is included on the Desktop 9.3 release media: on the ArcGIS Desktop Install DVD menu, it's the choice called ArcGIS Crystal Reports Wizard. The Desktop Setup no longer prompts you to install Crystal Reports. (You don't need to install the Crystal Reports XI Release 2 runtime to enable the Crystal Reports Wizard if you upgraded your Crystal Reports XI software to release 2).
Business Objects has released a new version of Crystal Reports: Crystal Reports 2008. If you have Crystal Reports XI, you can upgrade to Crystal Reports 2008 directly from Business Objects. See this page on the Business Objects Web site to upgrade: http://businessobjects.auc.com/ESRI2008/cd/index.html <http://businessobjects.auc.com/ESRI2008/cd/index.html> (Some international ESRI distributors may also be Business Objects resellers). Technical support for Crystal Reports 2008 is provided by Business Objects and may require an additional fee.
If you are new user of ArcGIS Desktop and you wish to use Crystal Reports 2008, you can buy it directly from Business Objects at the Web page mentioned above. To enable the Crystal Reports Wizard in ArcMap 9.3 to work with Crystal Reports 2008, you'll need to install the Crystal Reports XI Release 2 runtime mentioned above.
If you don't have any version of Crystal Reports installed, you can still enable the Crystal Reports Wizard in ArcMap 9.3 by installing the Crystal Reports XI Release 2 runtime mentioned above. This lets you to create, export, and print basic reports, and also open existing reports with the Crystal Reports wizard. However, you won't be able to perform the advanced formatting and authoring available with the full Crystal Reports product.
NOTE: ArcMap 9.3 continues to include the current simple report capability accessed using the Tools > Reports > Create Report command. These simple reports can be saved to PDF, RTF, or Text or printed. This simple report capability doesn't use Crystal Reports.
Tips |
Tip |
