Show Navigation | Hide Navigation
You are here:
Extensions > Spatial Analyst > Spatial Analyst functional reference > Extraction (Spatial Analyst)
Extract by Mask
Release 9.3
Last modified September 7, 2011
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Extraction (Spatial Analyst)"
Related Topics
Extracts the cells of a raster that correspond to the areas defined by a mask.
Illustration
Extract by Mask illustration
Command Line:
ExtractByMask_sa InRas1 InRas2 OutRas
Usage tips
Command line syntax
An overview of the Command Line window
ExtractByMask_sa <in_raster> <in_mask_data> <out_raster>
Parameter Explanation Data Type
<in_raster>
The input raster from which cells will be extracted.
Composite Geodataset
<in_mask_data>
Input mask data defining areas to extract.
This is a raster or feature dataset.
When the in_mask_data is a raster, NoData cells on the mask will be assigned NoData values on the output raster.
<out_raster>
The raster to be created.
Raster Dataset
Data types for geoprocessing tool parameters
Command line example
ExtractByMask_sa C:/data/raster1 C:/data/raster2 C:/data/final_1
Scripting syntax
About getting started with writing geoprocessing scripts
ExtractByMask_sa (in_raster, in_mask_data, out_raster)
in_raster (Required)
in_mask_data (Required)
out_raster (Required)
Raster Dataset
Script example
# ExtractByMask_sample.py
# Description:
#   Extracts the cells of a raster that correspond with the areas
#   defined by a mask.
# Requirements: None
# Author: ESRI
# Date: Sept 6, 2005
# Import system modules
import arcgisscripting
# Create the Geoprocessor object
gp = arcgisscripting.create()
try:
    # Set local variables
    InRaster = "C:/data/raster1"
    InMask = "C:/data/raster2"
    OutRaster = "C:/data/final_1"
    # Check out Spatial Analyst extension license
    gp.CheckOutExtension("Spatial")
    # Process: ExtractByMask
    gp.ExtractByMask_sa(InRaster, InMask, OutRaster)
except:
    # If an error occurred while running a tool, then print the messages.
    print gp.GetMessages()
Map Algebra syntax
See SelectMask
ArcObjects syntax
See Raster
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
