Adding a table to a layout |
Release 9.3
Last modified April 24, 2009 |
![]() ![]() ![]() Print all topics in : "Displaying tables and attribute information" |
This topic was updated for 9.3.1.
When creating a layout, you can display attribute tables on it to help describe the features your map shows. The appearance of the table in the table window defines how it will look on the layout. Thus, you'll want to set the text font and size before you add the table to the layout. Once added, any additional formatting to the table window won't affect its display on the layout.
You determine which rows and columns will display on the layout by arranging the data in the table window beforehand. The row and column that appear in the upper-left corner of the table window define what appears in the upper-left corner of the table on the layout. As you enlarge the table frame on the layout, you'll see more rows and columns; however, the data displayed in the upper-left corner will not change. ArcMap will only display an entire row or column so a row or column will not appear until the table frame is large enough.
You can add several table frames from a single table to a layout, but once you've added a table frame to a layout, you can't change its appearance. Instead, delete the table frame, make adjustments to the appearance of the table window, then add the table to the layout again.
To show just the selected rows in the table frame, click the selected button on the table before adding it to the layout. Selections made afterward do not affect the data in the table frame. If the All button is selected when the table is added, the selection is ignored. Any edits you make to the table will automatically be reflected in the table on the layout.
