Show Navigation | Hide Navigation
You are here:
Geoprocessing > Using geoprocessing tools > Using the tool dialog
Working with Results
Release 9.3
Last modified January 26, 2009
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Using the tool dialog"
Whenever you execute a tool using its dialog or as a command in the Command Line window, information about the execution is written as a result in the Results tab of the ArcToolbox window.
Result in the Result tab
There are a number of useful things you can do with results, such as
Unlike the progress dialog or the Command Line window, the Results tab maintains information between application sessions. That is, you can retrieve information about a tool you executed weeks ago. Results are kept until you delete or remove them. Results are part of the geoprocessing settings, which are written when the application closes and read when an application is opened.
Learn more about geoprocessing settings.
NOTE: Results are not created for tools executed within a script or model, only those executed using the tool dialog or in the command line.
Each result contains the following, in order:
Components of a result
Input and output datasets are shown with the appropriate dataset icon (such as Polygon dataset icon for polygons). Input and output values are shown with the value icon (Value icon).
Useful operations are found on context menus, which you open by right-clicking an entry in the Results tab. Each of these context menus is described below.
Current Session
Current session context menu
Previous Sessions
Previous session context menu
Result
Result context menu
Result context menu
If the tool executed on ArcGIS Server, the context menu will have three additional choices, as illustrated below.
Server tool result context menu
Input or output dataset
Dataset context menu
You can drag and drop datasets from the result into a tool dialog.
If your input or output dataset is named <data in local temp location> as shown below, the data resides in memory or in your system's temporary folder. The data will not be deleted as long as you have an ArcMap layer that references the data.
Learn more about preserving temporary data.
Data in temporary location
If you want to preserve the data, you should probably copy it from this temporary location to a known location. An easy way to do this is to use the Copy tool, dragging and dropping the dataset from the result into the input features parameter of the tool.
Input or Output values
Value context menu
Value context menu
You cannot drag and drop the text of an input or output value.
Environments
Under Environments, you'll find environment settings that were in place when the tool was executed. Only nonempty (not blank) environment settings are listed. Note that environment settings that have no effect on tool execution will be listed.
Environment settings
There is no context menu for environments or their settings.
Results, history, and metadata
Whenever a tool is executed, information about the execution is written to
Unlike the progress dialog or the Command Line window, the results tab maintains information between application sessions. That is, you can retrieve information about a tool you executed weeks ago.
Results are not part of the geoprocessing settings that you can save to a file. Results are kept until you delete or remove them.
Results duration
You want to manage the number of entries in the Result tab for two reasons:
To help you manage the number of results, you can choose a duration for keeping results, as shown below.
Keep results younger than option
Keep result younger than option
When you close ArcCatalog or a map document, entries older than the duration you choose will be removed from the Results tab.
NOTE: No data will be deleted—just the entries in the Results tab are removed.
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
