Differences between geoprocessor versions |
Release 9.3
Last modified June 3, 2010 |
Print all topics in : "Accessing tools within a geoprocessing script" |
This topic was updated for 9.3.1.
At 9.3, geoprocessing Python scripts can create either a 9.3-version geoprocessor or a 9.2-version geoprocessor. The 9.3-version geoprocessor was created to provide an geoprocessing experience that is more consistent with the Python language, provide easy–to–use Python objects such as Lists and Booleans, and provide richer geoprocessing objects, while still allowing you the ability to run geoprocessing scripts created at 9.2.
Which geoprocessor version you use affects numerous methods, properties, and objects. The differences between the 9.3 and 9.2 geoprocessor can be summarized into the following categories.
Learn more about comparing the 9.3-version and 9.2-version geoprocessor
| Property/Method | 9.3-version geoprocessor | 9.2-version geoprocessor |
| Any geoprocessing tool | Result Object | Depends on the tool. The type will vary depending on the tool's output. |
| ListDatasets
ListEnvironments ListFeatureclasses ListFields ListIndexes ListRasters ListTables ListToolboxes ListTools ListWorkspaces |
Python List | Enumeration |
| OverWriteOutput
Exists |
Python Boolean | Integer (1, 0) |
| TestSchemaLock | Python Boolean | String (TRUE, FALSE, ERROR) |
| RelationshipClassNames
Fields Indexes Domains |
| Extent | Extent Object | A semicolon delimited string: XMin; YMin; XMax; YMax |
| Extent | Extent Object | A space delimited string: XMin YMin XMax YMax |
| Centroid
TrueCentroid LabelPoint FirstPoint LastPoint |
Point Object | A space delimited string: X Y |
| IsMultiPart | Python Boolean | String (TRUE, FALSE) |
| Editable
IsNullable Required |
| IsAscending | Python Boolean | String (TRUE, FALSE) |
| IsUnique | Python Boolean | String (TRUE, FALSE) |
| Enabled
Altered HasBeenValidated ClearMessage HasError HasWarning |
| Clone | Python Boolean | Integer (1, 0) |
| Extent | Extent Object | A space delimited string: XMin YMin XMax YMax. |
| GetAttributeNames
GetDimensions GetDimensionsByVariable GetVariables GetVariablesByDimension |
| Fields | Python List | Enumeration |
Using a 9.2-version geoprocessor is similiar to using a geoprocessor created using win32com.client. However, the following methods are supported only when using the arcgisscripting module:
