AddIDMessage method |
Release 9.3
Last modified January 19, 2010 |
![]() ![]() ![]() Print all topics in : "Properties and Methods" |
This topic was updated for 9.3.1.
Allows you to use system messages with a script tool
NOTE: Supported only when the geoprocessor is instantiated using the arcgisscripting module; not supported when using the win32com module. Learn more about creating the geoprocessor object
Part | Description |
object | The instantiated geoprocessing object. |
MessageType | Keyword MessageType defines whether the message will be an error or a warning. Valid MessageTypes are
MessageID | The message ID allows you to reference existing messages for your scripting errors and warnings.
A list of IDs that can be used are provided under Understanding geoprocessing tool errors and warnings. |
AddArgument1 | Optional. Depending on which message ID is used, an argument may be necessary to complete the message.
Common examples include dataset or field names. |
AddArgument2 | Optional. Depending on which message ID is used, an argument may be necessary to complete the message.
import arcgisscripting import sys gp = arcgisscripting.create(9.3) inFeatureClass = gp.GetParameterAsText(0) outFeatureClass = gp.GetParameterAsText(1) try: # If the output feature class already exists, raise an error # if gp.Exists(inFeatureClass): raise "OverWriteError" else: # # Additional processing steps # except "OverwriteError": # Use message ID 12, and provide the output feature class # to complete the message. # gp.AddIDMessage("Error", 12, outFeatureClass)
