USE Data Transformation Approximations
This topic describes the nature and applicability of the geodetic transformation techniques supported by the coordinate conversion system. The USE clause present in each datum definition identifies the technique that will be applied to transform coordinates between datums.
With few exceptions, the geodetic transformation is a mathematical process by which geographic coordinates are converted from some datum to the WGS84 reference ellipsoid.
Available geodetic transformation methods:
AGD66 to GDA94 via Grid File
AGD84 to GDA94 via Grid File
ATS77 to CSRS via Grid File
Bursa/Wolf Transformation
CSRS to NAD27 via Grid Files
CSRS to NAD83 via Grid Files
DHDN to ETRS89 via Grid File
ED50 to ETRF89 via Grid Files
ETRF89
Four Parameter Transformation
GDA94, No Shift Required
HARN to NAD83 via NADCON
JGD2K via Grid Files
Molodensky
Multiple Regression ala DMA
NAD27 to NAD83 via NADCON
NAD83, No Shift Required
NTF to RGF93 via Grid File
NZGD2K, No Shift Required
NZGD49 to NZGD2K via Grid File
Seven Parameter Transformation
Six Parameter Transformation
Three Parameter Transformation
WGS72 to WGS84 via DMA Formula
WGS84, No Shift Required
