General Map Properties FeedbackFeedback E-mail this topicE-mail this topic Print this topicPrint this topic
You can use the General page to set attribution and descriptive information about the map and whether to display that descriptive information when the map is opened or whether to open the map directly as a Presentation.
To display the General page of the Map Properties dialog, click the ArcGIS Explorer Button , then click the Map Properties button and then click the General tab.
Set these options
Map Attribution and Description
Use the Attribution text box to enter any information pertaining to the lineage, copyright, and permissions of the map. If you want this information to be presented when the map is opened, add it to the Description field either in the form of text or included with other information at a URL. The Description field can contain plain text, HTML markup, or a URL; it follows the same conventions as text you enter in a popup window. You can display the contents of the Description field when the map is opened by choosing Show map description in the When the Map Opens section. To edit the text of the Description click the Edit... button.
Learn more about HTML markup
Top of Page
When the Map Opens
The When the Map Opens options control what happens when the map is opened. You can choose to display the Map Description or to display the map directly as a Presentation. Note that the Start presentation setting applies only when you open the map by double-clicking it in Windows Explorer and ArcGIS Explorer is not already running. If you choose None, no action related to these properties will occur at startup; however any text in the Attribution and Description text boxes is retained on the General page and may be viewed by opening the Map Properties dialog.
Top of Page
