Add Geodatabase Data E-mail this topicE-mail this topic Print this topicPrint this topic
When you select Geodatabase Data in the Home tab's Add Content split button's list of content types, you'll be able to browse for a file geodatabase or create and connect to an ArcSDE database to access its contents.
File Geodatabases
A file geodatabase is a collection of various types of GIS datasets held in a file system folder. This is the recommended native data format for ArcGIS stored and managed in a file system folder. Intended for a single user or a small workgroup, each dataset is a separate file on disk, and the file geodatabase is a file folder on disk that holds its dataset files. The primary goals of a file geodatabase are to: File geodatabases also include a read-only compression option that allows users to create a read-only, highly compressed, and optimized geodatabase.
To add content in a File Geodatabase
  1. Select Geodatabase Data in the Home tab's Add Content split button's list of content types.
  2. Choose File Geodatabase as the Geodatabase type in the Add Geodatabase dialog.
  3. Browse for or enter the full pathname of the geodatabase to open:
  4. Click Next.
  5. Choose one or more datasets from the list that appears:
    Hold down Shift to select an adjacent range of items; hold down Ctrl to select multiple, non-adjacent items.
  6. Click Add.
    The items you selected are added as layers to the map. You can change the order in which the layers you selected draw by selecting a layer and clicking Bring to Front or Send to Back in the Organize group on the Tools tab. In addition, you can click the Organize group's dialog launcher to display the Manage Layers dialog to change the drawing order of layers.
Notes
ArcSDE Geodatabases
ArcSDE is ESRI's technology for accessing and managing geospatial data within relational databases. ArcSDE technology supports reading and writing of multiple standards, including (among other data storage options) Open Geospatial Consortium, Inc. (OGC) standards for simple features, the International Organization for Standardization (ISO) standard for spatial types, and the Oracle Spatial format.
This release of ArcGIS Explorer supports vector data and raster dataset data types in three tier connections; to establish two tier connections, Direct Connect, install the ArcGIS Explorer Data Access Expansion Pack.
To get the ArcGIS Explorer Data Access Expansion Pack
  1. Click the ArcGIS Explorer Button .
  2. Click the ArcGIS Explorer Options button:
  3. Click Resources and then click Expansion Packs:
  4. In the dialog that appears, click Get Expansion Packs...
  5. Download the Data Access Expansion Pack from the ESRI web site.
To connect to an ArcSDE geodatabase
The following steps provide a generic overview of creating a Database Connection and connecting to it, once it's been established. Your system administrator may have already created a Database Connection for you and in many cases, may have already created a map file (.nmf) that has all the necessary connection information in it.
  2. Choose ArcSDE Geodatabase as the Geodatabase type in the Add Geodatabase dialog.
  3. Specify Server, Service, Database, and authentication information:
  4. Click Next.
  6. Click Add.
To connect to existing geodatabases
  2. In the Add Geodatabase dialog choose an existing connection:
    If you want to specify a new or different connection, click the area at the bottom of the dialog:
