Adding a server object container
Release 9.3.1 E-mail This Topic Printable Version Give Us Feedback
Server object container (SOC) machines host services and are the work centers of your GIS server. For your GIS server to utilize these SOC machines, you need to link them to the server object manager (SOM). When you install all the components of ArcGIS Server on one machine, the SOC is automatically linked to the SOM and you don't have to take any further action. If you install the components of ArcGIS Server across multiple machines, then you need to manually add the SOC as described below.
For a machine to function as a SOC, it needs to have the Server Object Container component of ArcGIS Server installed on it.
Additionally, you should run the GIS Server post install on the container machine, specifying the same SOM account and SOC account names and passwords that you use on all the other machines of your ArcGIS Server system.
How to add a server object container in Manager
To add a server object container machine from ArcGIS Server Manager:
  1. Click the GIS Server tab and click Host Machines.
  2. Click Add Host Machine.
  3. Type the machine name.
    Note: You must type the exact name of the machine; do not type "localhost".
  4. Optionally, set a capacity value. The default is unlimited capacity.
    Learn more about capacity.
  5. Optionally, add a description for the machine.
  6. Click Add.
How to add a server object container in ArcCatalog
To add a server object container machine in ArcCatalog, follow these steps:
  1. Find the GIS Servers node in the Catalog tree and, if necessary, double-click your server to make a connection.
  2. Once you've connected, right-click the name of your GIS server and click Server Properties.
  3. Click the Hosts tab and click Add.
  4. Type the machine name or click the browse button to locate it on the network.
  5. Optionally, set a capacity value. The default is unlimited capacity.
  6. Optionally, add a description for the machine.
  7. Click OK.
  8. Follow the same steps to add any other container machines you want to connect to the GIS server.
