ArcGIS Server Banner
DB2 DEFAULTS keyword
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Note:This topic was updated for 9.3.1.
As the name indicates, the settings under the DEFAULTS configuration keyword are used by default when you create tables, feature classes, raster datasets, and indexes. If you do not specify a different keyword when data is created in the geodatabase, or if you specify a keyword that is missing some necessary parameters, values from the DEFAULTS keyword are used.
You need to supply the information shown in brackets (<>) and uncomment the associated TABLESPACE lines by removing the # sign. The parameters grouped under the DEFAULTS keyword should be set to values that apply to most of the data in your geodatabase.
The first set of DEFAULTS parameters are for DB2 for on Linux, UNIX, and Windows.
##DEFAULTS
A_INDEX_ROWID	""
A_INDEX_SHAPE     	""
A_INDEX_STATEID	""
A_INDEX_USER	""
#A_STORAGE	"IN <TABLESPACE> INDEX IN <TABLESPACE> LONG IN <TABLESPACE>"
B_INDEX_ROWID	""
B_INDEX_SHAPE      	""
B_INDEX_TO_DATE	""
B_INDEX_USER	""
B_RUNSTATS      "YES"
#B_STORAGE	"IN <TABLESPACE> INDEX IN <TABLESPACE> LONG IN <TABLESPACE>"
BLK_INDEX_COMPOSITE		""
#BLK_STORAGE "IN <TABLESPACE> INDEX IN <TABLESPACE> LONG IN <TABLESPACE>"
#AUX_STORAGE "IN <TABLESPACE> INDEX IN <TABLESPACE>"
#BND_STORAGE "IN <TABLESPACE> INDEX IN <TABLESPACE>"
#RAS_STORAGE "IN <TABLESPACE> INDEX IN <TABLESPACE>"
D_INDEX_DELETED_AT	""
D_INDEX_STATE_ROWID	""
#D_STORAGE	"IN <TABLESPACE> INDEX IN <TABLESPACE> LONG IN <TABLESPACE>"
BLOB_OPTION	"LOGGED NOT COMPACT"
BLOB_SIZE        "1M"
CLOB_OPTION	"LOGGED NOT COMPACT"
CLOB_SIZE        "32K"
#MAX_CACHED_CURSORS "80"
#XML_DOC_STORAGE         "IN <TABLESPACE> INDEX IN <TABLESPACE>"
XML_DOC_LOB_SIZE          "1M"
XML_DOC_VAL_LOB_SIZE      "1M"
XML_DOC_UNCOMPRESSED_TYPE ""
#XML_IDX_STORAGE         "IN <TABLESPACE> INDEX IN <TABLESPACE>"
XML_IDX_INDEX_ID      ""
XML_IDX_INDEX_TAG     ""
XML_IDX_INDEX_DOUBLE  ""
XML_IDX_INDEX_STRING  ""
XML_IDX_FULLTEXT_UPD_FREQUENCY   ""
XML_IDX_FULLTEXT_UPD_MINIMUM     ""
XML_IDX_FULLTEXT_UPD_COMMIT      ""
XML_FULLTEXT_IDX_IDXDIRECTORY    ""
XML_IDX_FULLTEXT_WKDIRECTORY     ""
XML_IDX_FULLTEXT_LANGUAGE        ""
XML_IDX_FULLTEXT_CCSID           ""
END
The following set of DEFAULTS parameters are for DB2 for z/OS:
##DEFAULTS
A_INDEX_ROWID	""
A_INDEX_SHAPE   ""
A_INDEX_STATEID	""
A_INDEX_USER	""
#A_STORAGE	"IN DATABASE <DATABASE NAME>"
B_INDEX_ROWID	""
B_INDEX_SHAPE   ""
B_INDEX_USER	""
B_RUNSTATS      "NO"
#B_STORAGE	"IN DATABASE <DATABASE NAME>"
#BLK_STORAGE "IN DATABASE <DATABASE NAME>"
#AUX_STORAGE "IN DATABASE <DATABASE NAME>"
#BND_STORAGE "IN DATABASE <DATABASE NAME>"
#RAS_STORAGE "IN DATABASE <DATABASE NAME>"
BLK_BLOB_OPTION ""
#D_STORAGE	"IN DATABASE <DATABASE NAME>"
BLOB_OPTION	""
BLOB_SIZE       "1M"
CLOB_OPTION	""
CLOB_SIZE        "32K"
UI_TEXT	""
XML_DOC_STORAGE       ""
XML_IDX_STORAGE       ""
XML_IDX_INDEX_ID      ""
XML_IDX_FULLTEXT_IDXDIRECTORY       ""
END
NOTE: XML parameters do not affect geodatabases on DB2 for z/OS, since XML is not supported for these geodatabases at this time.
See Also
  • The DEFAULTS keyword
  • DBTUNE configuration keywords
  • The dbtune file and the DBTUNE table
