ArcGIS Server Banner
Enabling archiving
Enabling archiving
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Note: This topic was updated for 9.3.1.
Enabling archiving is similar to registering a dataset as versioned. For each dataset for which archiving is enabled, a new archive class is created. When enabling archiving, all attributes and all rows in the DEFAULT version of the dataset or object class are copied to the archive class. The time it takes to complete the creation of the archive class depends on the size of the dataset being enabled. The archive class has the same schema as the original dataset with additional date attributes, gdb_from_date and gdb_to_date, to record the time stamp for the effective lifespan of the archived row and a gdb_archive_oid attribute to uniquely identify each row.
archiving table
Representing the archive class as an independent feature class, as opposed to managing the historical rows in the delta table for the versioned table, means that the existence and size of the archive does not impact the efficiency of the database. Datasets can be unregistered as versioned without affecting or deleting the archive class. If a dataset is unregistered as versioned, the archive class becomes an object or feature class.
Once the dataset has had archiving enabled, all changes saved or posted to the DEFAULT version are additionally preserved in the archive class. You do not have the ability to append historical data to the archive class. Manually changing the archive class can lead to a corruption of your geodatabase archiving process.
To enable archiving, the data must be registered as versioned. Select and right-click the object and choose the Enable Archiving command from the Archiving pull-right menu:
Enabling archiving
Schema changes
The archive class is used to preserve the edit transactions that occur on the enabled dataset or object class. Therefore, the schema of the archive class must be consistent with the dataset or object class.
Schema changes made to the dataset or object class are automatically pushed to the archive class. For example, if you add an attribute column to the feature class, that column is automatically added to the archive class. If you delete an attribute column, that column will also be removed from the archive class, removing all the archived information for this column.
Geodatabase archiving does not create metadata regarding schema changes. The objective of geodatabase archiving is to preserve the edit transactions of enabled classes.
Changes to geodatabase behavior will be available to the archive class, but the actual change to the ArcSDE repository is not archived. Documenting geodatabase behavior change is the resposibility of your workflow procedures.
Do not alter the schema of the archive class directly. Should you directly alter the archive class, you will potentially corrupt this class and lose your archived transactions. ArcGIS limits access to the archive class to read-only, preventing direct editing of and schema changes to the archive class.
Tips on enabling archiving
See Also
  • Geodatabase archiving
  • Creating versions and setting permissions
  • Registering and unregistering data as versioned
  • The archive process
  • Disabling archiving
