ArcGIS Server Banner
Resolving conflicts interactively
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
About resolving conflicts interactively
Note: This topic was updated for 9.3.1.
If conflicts arise between your edited version and the target version when you reconcile, you can resolve these conflicts interactively in the conflict resolution dialog box. The Conflicts dialog box will appear only if you set your editing options to Automatically save changes only if there are no conflicts.
Learn about setting versioning edit options.
When you resolve conflicts, you are deciding which representation of the features and attributes you want to keep.
Conflicts can be resolved at several different levels:
Resolving conflicts does not save your edits to the parent version; posting your changes to the target version does that.
How to resolve conflicts
Field level
  1. Choose an Object ID from the list of Conflicts.
  2. In the list box in the upper right of the Conflicts dialog box, right-click the field for which there is a conflict. If you want to choose multiple fields, hold down the Ctrl key and click on each one you want to choose.
  3. In the context menu, click the representation—Pre-Reconcile, Conflict, or Common Ancestor—that holds the attribute value you want to use to resolve the conflict.
Tip
    If one editor altered a feature and another editor deleted the feature, you would not be able to replace with any of the representations, and those menu options would be deactivated.
Row level
  1. In the Conflicts list, right-click the Object ID of the feature for which there are one or more conflicts.
  2. In the context menu, click the option—Replace Object With Pre-Reconcile Version, Replace Object With Conflict Version, or Replace Object With Common Ancestor Version—to designate which representation will be used to replace the attributes in conflict in that feature in your edit representation.
Class level
  1. In the Conflicts list, right-click the feature class for which you want to resolve conflicts.
  2. Click the option—Replace Objects With Pre-Reconcile Version, Replace Objects With Conflict Version, or Replace Objects With Common Ancestor Version—to designate which representation will be used to replace all attributes in conflict in all features in your edit representation.
Tip
    When you click or right-click on a feature class in the Conflicts list, the fields and attributes on the right of the dialog box will disappear, as will the conflict displays at the bottom of the dialog box.
Root level
  1. In the Conflicts list, right-click the root of the conflicts list tree, Conflicts.
  2. On the context menu, click an option—Replace Objects With Pre-Reconcile Version, Replace Objects With Conflict Version, or Replace Objects With Common Ancestor Version—to designate which representation will be used to replace all attributes in conflict in all features in all feature classes in your edit representation's Conflicts list.
Tip
See Also
  • Reviewing conflicts
  • Reconciling a version
