ArcGIS Server Banner
SQL Server DEFAULTS keyword
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Note:This topic was updated for 9.3.1.
As the name indicates, the settings under the DEFAULTS configuration keyword are used by default when you create tables, feature classes, raster datasets, and indexes. If you do not specify a different keyword when data is created in the geodatabase, or if you specify a keyword that is missing some necessary parameters, values from the DEFAULTS keyword are used.
The parameters grouped under the DEFAULTS keyword should be set to values that apply to most of the data in your geodatabase. The following values are what are present in the dbtune table if you do not customize it.
##DEFAULTS
NUM_DEFAULT_CURSORS	-1
CROSS_DB_QUERY_FILTER  0
UI_TEXT	""
A_CLUSTER_ROWID	0
A_CLUSTER_SHAPE	1
A_CLUSTER_STATEID	0
A_CLUSTER_USER	0
A_CLUSTER_XML  0
A_CLUSTER_RASTER  0
A_INDEX_ROWID	"WITH FILLFACTOR = 75"
A_INDEX_SHAPE	"WITH FILLFACTOR = 75"
A_INDEX_STATEID	"WITH FILLFACTOR = 75"
A_INDEX_USER	"WITH FILLFACTOR = 75"
A_INDEX_XML	"WITH FILLFACTOR = 75"
A_INDEX_RASTER	"WITH FILLFACTOR = 75"
A_TEXT_IN_ROW   256
A_STORAGE	""
B_CLUSTER_ROWID	0
B_CLUSTER_SHAPE	1
B_CLUSTER_USER	0
B_CLUSTER_XML 0
B_CLUSTER_RASTER 0
B_INDEX_ROWID	"WITH FILLFACTOR = 75"
B_INDEX_SHAPE	"WITH FILLFACTOR = 75"
B_INDEX_USER	"WITH FILLFACTOR = 75"
B_INDEX_XML	"WITH FILLFACTOR = 75"
B_INDEX_RASTER	"WITH FILLFACTOR = 75"
B_INDEX_TO_DATE "WITH FILLFACTOR = 75"
B_STORAGE	""
B_TEXT_IN_ROW   256
D_CLUSTER_ALL	0
D_CLUSTER_DELETED_AT	1
D_INDEX_ALL	"WITH FILLFACTOR = 75"
D_INDEX_DELETED_AT	"WITH FILLFACTOR = 75"
D_STORAGE	""
F_CLUSTER_FID	1
F_INDEX_AREA	"WITH FILLFACTOR = 75"
F_INDEX_FID	"WITH FILLFACTOR = 75"
F_INDEX_LEN	"WITH FILLFACTOR = 75"
F_STORAGE	""
F_TEXT_IN_ROW   256
S_CLUSTER_ALL	1
S_CLUSTER_SP_FID	0
S_INDEX_ALL	"WITH FILLFACTOR = 75"
S_INDEX_SP_FID	"WITH FILLFACTOR = 75"
S_STORAGE	""
RAS_STORAGE       ""
RAS_CLUSTER_ID   1
RAS_INDEX_ID    "WITH FILLFACTOR = 75"
BND_STORAGE       ""
BND_CLUSTER_ID   0
BND_INDEX_ID    "WITH FILLFACTOR = 75"
BND_CLUSTER_COMPOSITE   0
BND_INDEX_COMPOSITE    "WITH FILLFACTOR = 75"
AUX_STORAGE       ""
AUX_CLUSTER_COMPOSITE   1
AUX_INDEX_COMPOSITE    "WITH FILLFACTOR = 75"
BLK_STORAGE       ""
BLK_CLUSTER_COMPOSITE   1
BLK_INDEX_COMPOSITE    "WITH FILLFACTOR = 75"
XML_DOC_INDEX	"WITH FILLFACTOR = 75"
XML_DOC_STORAGE	""
XML_DOC_TEXT_IN_ROW	1024
XML_DOC_UNCOMPRESSED_TYPE	"BINARY"
XML_IDX_CLUSTER_DOUBLE	0
XML_IDX_CLUSTER_ID			0
XML_IDX_CLUSTER_PK			1
XML_IDX_CLUSTER_STRING	0
XML_IDX_CLUSTER_TAG		0
XML_IDX_FULLTEXT_CAT		"SDE_DEFAULT_CAT"
XML_IDX_FULLTEXT_LANGUAGE
XML_IDX_FULLTEXT_TIMESTAMP	1
XML_IDX_FULLTEXT_UPDATE_METHOD 		"CHANGE_TRACKING BACKGROUND"
XML_IDX_INDEX_DOUBLE	"WITH FILLFACTOR = 75"
XML_IDX_INDEX_ID		"WITH FILLFACTOR = 75"
XML_IDX_INDEX_PK		"WITH FILLFACTOR = 75"
XML_IDX_INDEX_STRING	"WITH FILLFACTOR = 75"
XML_IDX_INDEX_TAG	"WITH FILLFACTOR = 75"
XML_IDX_STORAGE
XML_IDX_TEXT_IN_ROW	128
GEOM_SRID_CHECK			1
GEOMETRY_STORAGE       "SDEBINARY"
GEOMTAB_OUT_OF_ROW	0
GEOMTAB_PK				"WITH FILLFACTOR = 75"
GEOMTAB_STORAGE		""
PERMISSION_CACHE_THRESHOLD  250
UNICODE_STRING   "TRUE"
COLLATION_NAME   ""
END
See Also
  • The DEFAULTS keyword
  • DBTUNE configuration keywords
  • The dbtune file and the DBTUNE table
