ArcGIS Server Banner
ST_AsBinary
ST_AsBinary
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Note: This topic was updated for 9.3.1.
Definition
ST_AsBinary takes a geometry object and returns its well-known binary representation.
Syntax
Oracle
sde.st_asbinary (g1 sde.st_geometry)
PostgreSQL
st_asbinary (g1 st_geometry)
Return type
ST_Geometry
Example
This example populates the WKB column, with an ID of 1111, from the GEOMETRY column, with an ID of 1100.
Oracle
CREATE TABLE sample_points (id integer, geometry sde.st_geometry, wkb blob);
INSERT INTO SAMPLE_POINTS (id, geometry) VALUES (
1100,
sde.st_point (10, 20, 0)
INSERT INTO sample_points (id, wkb) VALUES (
1111,
(SELECT sde.st_asbinary (geometry) FROM sample_points WHERE id = 1100)
SELECT id, sde.st_astext (sde.st_geomfromwkb (wkb, 0))
FROM sample_points
WHERE id = 1111;
ID 	Point
1111     POINT (10.00000000 20.00000000)
PostgreSQL
CREATE TABLE sample_points (id integer, geometry st_geometry, wkb bytea);
INSERT INTO sample_points (id, geometry) VALUES (
1100,
1111,
(SELECT st_asbinary (geometry) FROM sample_points WHERE id = 1100)
SELECT id, st_astext (st_geomfromwkb (wkb, 0))
FROM sample_points
WHERE id = 1111;
ID 	st_astext
1111     POINT (10 20)
See Also
  • An overview of SQL functions used with ST_Geometry types
